On second notes i have just run Starcitizen with gpu z in the background. and the cards appear to be going to 1371.8 mhz each.
however one card is running at a max power consumption of 101.9% whilst the other 115.2%, any ideas
Right,
Fresh bios from TPU, both flashed, both detected as flashed, system BSOD as soon as the cards do anything, no SLI options in NVCP but showing both cards as present.
Also tried 3 other SLI bridges, same thing.
Complete head ****
Edit: tried to disable PCI lanes, I just get no display from the one active lane![]()
Hi again im back!
still tinkering with my graphics cards
I have changed the cables, both cards used to run on daisy chained 6+8pin cables, now each power point has it's own cable
this improved stability to somewhat of a degree
now what i am trying to fix is the Vdroop sli issue, When i use the vdroop for msi afterburner, it only activates on one gpu and causes some weird scaling issues. stopping the other card getting to the same speed.
I can't use the great Zawarudos tool as i could not install the provided afterburner (got a error about it being outdated) But i know that the tool has a Vdroop sli option on it.
Any suggestions for fixing this?
Kind regards
You can use the latest afterburner and add the 3 lines like you would do for the one in the OP.
! To get the 1.3VSkynet.
Yeah i have already done that! To get the 1.3V
It is the part after that to stop the clocks not scaling, there set at the same settings, yet one runs at 900mhz-1000mhz and the other runs at 1350mhz
not sure if this is just a limitation of some sort, maby because i havent flashed the bios? i don't know what bios i should be using
KGB is not ideal for Kepler and if you read the OC.Net thead you will see why.
It was suffice on Fermi.
@ PFS38, That is your opinion not others, remember that.
Do not give me any of this sheep BS or egotistical attitude, and you follow unwinder so touche.
I can mod a bios is KGB, does not do much for a 780Ti and FYI the 780Ti cannot be voltage hacked by software the same as a 780.
Skynet did not work for me but the peep made me a Bios with the rev 2 EVGA Bioses (my card is newer so not same Bioses as launched card) and kept giving me beta builds every day till I was happy.
I am not a fanboy of Skynet but in the end with a new revision it works.
Keep blowing your own trumpet.
