Thing is I already know what he card can do I just want to run the fans at less than 26% and the only way I can currently do this is through an alternate BIOS but then I lose the ability to overclock the GPU.
As per my previous post the problem being that I believe the Nvidia drivers override the BIOS settings based on the card that they detect. If they pick up that the card is a reference edition then the fan speed is set to 26% regardless of what the BIOS is set to. It's only when you flash to a non reference BIOS that the fan speeds reduce. Ideally it would be great if this feature could be disabled but I guess they put it in as some form of protection. I'm starting to think my only option is to fit some slower rated PWM fans.If you are happy with every aspect of your current bios except the fan control then try and edit it with kepler bios editor 1.27.
As per my previous post the problem being that I believe the Nvidia drivers I'm starting to think my only option is to fit some slower rated PWM fans.
what happens if you just type in nvflash inno3d.rom without the switches?
