It's zotac not gigabyte
Trying to flash a GTX 780 reference card with the skyn3t-3A-SC-rev3-941.rom,
I do get PCI Subsystem ID mismatch but board ID matches
I'm unable to run the version of AB that is bundles with the BIOS's on your first post I get a message saying that some components are expired, missing or corrupt. I've followed the instructions using the latest version of AB and added the entries but this made no difference. I will try again though and report back.That sounds to me like the flash has worked but you have not or not correctly added the 3 lines of text to the ven10 cfg file in the AB folder.
Can you take a screenshot of your AB screen please.
That looks spot on for just normal day to day stuff and gaming but if you want to see what the card can do, you need to move that "Auto" slider to no more than 1.25V (effective 1.275v) as you are on air and run a bench. Make sure you keep an eye on the temps. For a decent Titan, you should be able to hit 1300Mhz with those volts but for a poor one, 1200Mhz might be hard to reach, but don't hammer it and take your time![]()
