No idea about orientation.
Both the Sapphire and MSI cards are great. Personally I'd save the £15 and grab the Sapphire.
The MSI is lovely, but there's no point paying more for essentially the same thing.
Looking like you've got a good one, that's a great voltage for 1200![]()
I've gone for the Gigabyte 7850 OC as my 4850 died last night.
Reading more of thins thread I'm thinking maybe I should have gone MSI?
Thanks, it's not bad, but I'm hoping I don't need to increase it whilst I'm upping the memory clocks.
Looking back at the thread it looks like the Sapphire cards are the ones to go for. It cools well, isn't loud, looks good and overclocks the best.
You need to tick the box in the advanced page that says 'remember these settings', can't remember the exact wording. But if you tick that it'll load whatever your settings are when you last closed it.
Not really. If you see problems, it is most likely the card itself or the drivers.Is it possible my monitor will struggle with ths new card?
Monitor is Samsung 940 BW
only setting i see is "keep setting for next start on close application," however you must open the application again for it to default to those settings. otherwise if the program isn't running, it goes back to stock clocks.
Using 12.3 atm. I can't describe it much more than a very faint white line acorss the top of the screen. Stock the card on all efault setings and it's still there. Temps are not high either. 35c Under load.
