Man of Honour
- 23 Mar 2011
- West Side
Yes .Will the case work all fine? And what do you mean by do I need wifi?
Do you want Wi-Fi (wirless)on the motherboard to connect to the internet or will you be using a cable from your router ?
If you don't need Wi-Fi you can get a cheaper motherboard as I mentioned before.
