That's on the old DDR5 structure though...this is a total new tech...
Never under estimate old tech !!!
Photography is a good example where old tech is better for quality than new tech.
If you look at a photo taken on an old 100+ year old plate camera it will knock spots off modern cameras, they are so good pros still use them.
Again a genuine question in the top tier gfx card phenomena
@ 1440p and 4k....
Not enough memory... 4GB isn't enough for newer games in 1440p, let alone 4k!
If it shocked everyone and came out as 150% the speed of Titan X in most things, then I'd be tempted... but not otherwise.
- ATi (AMD) Crossfire support is terrible and slow
- no GSync
Freesync ....
poostink
True, but I cant see hbm being that much difference in my case and res. Still on 1920x1200 here. Most likely moving to 2560x1440, which 6gb of gddr5 should cope with ok. As for 4k I think its way too early to adopt this res. You need multi gpu straight off the bat to deal with it. And with current cards such as the TX, that's the best part of two grand. Fury x may/may not change this. But for me personally, 4k is a long long way of.
@ 1440p and 4k....
