Yep and she's lovely![]()
Absolutely. I do a lot of my personal photos but I also take property photos for estate agents. It's a fantastic monitor and I have been surprised at how good the whites and blacks are. To have so much real estate at a high resolution is a dream.
Q: What is the distance between the desk and the bottom of the screen?
A: 6cm with the included stand/legs, vesa mounting is possible so with a separate mount you can do what you like.
regarding gaming if you were to play at 1440p then I guess you would switch on some AA, I've not done it but I could give it a try. I tried Fallout4 briefly tbh I found it disorientating due to the monitor size/distance you'd need to move back a bit for fast fps games. Mechwarrior is good and X Rebirth is exceptional with a big monitor. Looking forward to trying Elite this week.
But there are 2 ventilation slots at the base/bottom of the monitor. Which are blocked in your setup. Don't you care?Nope it just sits there happily. I knew before I bought it I wouldn't be able to use the stand as I have a small desk so one of the reasons I got the Iiyama over the Philips was the Iiyama is flat on the bottom where the Philips has the logo protruding. I measured everything and it sits perfectly in my field of view. I did think I would need some sort of bracket but once I got the monitor I tried it just sat on the desk and its extremely stable. I don't have any small children so theres no reason for anyone to touch it unnecessarily.
Here are a few more photos and as you can see the monitor has quite a thick base on the bottom of about 4" combined with the 12Kg weight makes it sturdy:
SNIP
I have been looking at these all morning and I am very tempted but I have some questions:
Gaming:
I can run almost all my games at a solid 60fps @ 4k currently(got a 28" 4k screen) so I'm not worried about it dropping below 60fps or even having a higher refresh rate like on some as I don't see a problem with 60fps for me anyway.
The division - I was running at 4k, but in heavy areas it dropped fps a bit, and I wasn't happy with turning down the gfx settings so I run it on 1440p instead now which still looks fantastic.
Has anyone tried a game on this at 1440p? How is the quality? Is the dpi high enough for this resolution without jaggies?
Fixed stand:
I currently have four monitors, and if I got this I would either run it on its own, or use this one in the middle with one either side and remove the top monitor meaning I could remove the legs on this and secure it lower, with the stand I already have.
I would probably keep my current 4k monitor and buy another so I can have them on either side of this, mainly because I like putting tv ahows/movies/monitoring software/discord etc on them when I am gaming.
I tried it in just cause 3 (1440p) and it didn't look that good tbh, probably because its a 40 inch screen.
Hey guys
I was considering picking one of these up for music production work.
I occasionally game and was wondering if this will cover that role as well? I have a 980ti but doubt ill get enough frames on 4K so will it be ok at 1440p as well?
Cheers!
Hey guys
Cheers!
I think it depends what games you like, my R9 290X can drive Elite Dangerous @4k not at a constant 60fps but 50+ for the most part. GTA V @4k is ok a bit laggy if I'm honest but if you drop the resolution down you always have the option of moving further away from the screen. Your 980ti is more powerful so I think you'll be ok as long as you are not into competitive Battlefield or CounterStrike.
Its amazing how small your classic 24" 1080p screen looks when you've used one of these for a few days.
