Anyone who had any issues with their monitor how long did it take over clickers customer service to get back to you? I know it was the bank holiday weekend but I've not had anything in 48 hours and I've left a comment in the customer service section this morning but no reply.
Just want to get the ball rolling or acknowledged at least.
Unlucky Double07
It really isn't sounding good this!
Also, I just noticed that there is a faint mark on the far right side of my panel...... as if someone had scuffed it, not noticeable unless looking at it from the right side under certain angles and lighting and it just so happens that the right side of my box had a bit of damage too, definitely seems like something happened with this batch of monitors and the right hand side of the box!
If it is just that, try set colors manually, e.g.I've been doing some comparisons with my PG348Q and VG249Q. Have to say the colours are very warm. Not sure this is really a bad thing but certainly the image looks a bit different.
My (GTX 1080) issues have gone away (touch wood..) since I did the DP 1.4 update mentioned earlier in the thread. It has slept at least a few times a day over the last couple and otherwise been in use for 11+ hours a day (joy of working from home...).
That's great news !
I heard back from iiyama tech support on the wake from standby issues.
Good news: they're aware it's a widespread problem, seem to think it might be fixable via software. Bad news: what they suggested didn't work for me, I'll post about it anyway maybe it helps one of you.
What they suggested: open the registry editor and navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers\. Delete the contents of the \Configuration\ and \Connectivity\ sub-directories. Restart PC, restart monitor. (I also suggest using DDU in safe mode to uninstall your GPU driver prior to this, then a clean reinstall)
Still, so far I've had mine for a fortnight and despite the occasional standby hiccup I'm very happy with the monitor. Performance and value combined are pretty much the best in the 34" ultrawide space right now.
Aye, cautiously optimistic... I do have a ticket logged with Iiyama technical support with my symptoms etc. which I am waiting to hear back on so will see what they say too.
Right, I have had a few flickers there as well as the sleep issue and then the right side of the monitor getting corrupted/stuck..... :/
Hopefully just a one of, will keep an eye on it.
