You're lucky to get Haribo, not had any in my latest orders![]()
I've said it before, I've been using OcUK since they were a dingy little place up in Fenton and not once have I had Haribo in an order.
They are perfectly legal but bow hunting is not in the UK! Handy for a zombie apocalypse though.....I saw some arrow heads like that in US but they were hinged at base so they opened out when they hit the poor animal they were aimed at.
Nice arrow heads though. Surprised they are legal with the namby pambies around today.
My dad brought some of those back from the US when he worked over there, he also brought back around 9 bows he's managed to buy in around 18 months![]()
These are only dinky 47uF parts as my amplifier uses dual diode valves to rectify the AC (5AR4) and they have a first filter capacitance limit of 60uF. Using anything larger can result in arcing inside the valve. The current capacitors are rated only to 500V. If an output valve fails to draw current, the supply voltage rises to around 540V which isn't good news for those caps. The usual cheat is to put two higher capacitance capacitors in series, which halves the effective capacitance but doubles the voltage limit.Interesting - 600V caps. Electrolytics ?
Most of mine were 450V 2200uF banks of 192 units for 3,000 kW variable speed drives. Slightly application I suspect................
Ah, Filmcaps. My apologies..................![]()
What does it do?
What does it do?
Got my wowstick, surprised how quick it came from 'China', ordered on the 29th December and arrived today. Saved a bit of money too as compared from Amazon.
