Indiana Jones and the Great Circle (2024)
Is anyone here playing this on Gamepass? I've been playing around with it and whenever I activate frame gen it's introducing a load of stuttering every 10 seconds or so.
Just wondering if the Gamepass version is borked or not.
Which GPU? Frame gen increases VRAM use so that could be the issue if you have a midrange 40 series card at high resolution.
4090 playing at 4k.
I don't appear to be the only one with an issue, seen a few posts on reddit about FG introducing stuttering.
I've just turned it off, it's not really required. I'm getting 60+ fps with DLSS Quality and everything cranked to max.
They spend years adding fixes to Windows, they aren't going to do much better on a single app :cry:
They are 60fps since the update, no need for them to be any higher really.
It really is awesome.I'm not even done in Giza yet so expect this will be into 30 hours to complete easily.
I'm getting huge frametime spikes all over the place on a 5800X3d, 4090 at 4k. Plenty of black screens when loading the next scene too. This using the Gamepass version.
Similar to the above, it's only a minor niggle but it doesn't seem to be hitting the max on my GPU (4800) or CPU (3900x) yet the frame rate drops. Only to about 80-85 on the extreme settings (or whatever it's called) using DLSS / DLAA @ 3840x1080. It's not a massive issue but just wondering why it wouldn't use the available hardware to stop the drops.
I'm sure there's going to be a few patches over the next few weeks so will see if that changes anything.
M.
Latest drivers, gamepass version on a 4080 - hits 15+GB VRAM on texture pool sizes above high - stutters a fair bit. Rolled back to prev drivers (561.09) and it uses about 15.4GB on supreme pool but doesn't stutter. Hmmm :)
Microsoft just should ditch game pass, too many games coming out on it with various issues exclusively GP related.
Yup I won't be renewing gamepass again unless they fix the issues that happen on launch day/week. Too many games with issues now.
Path tracing is also missing from the gamepass version.
Running okay for me, will probably play with path tracing on medium, the other two options hurt performance a little too much. With just global illumination it's around 150fps, on medium it's around 90-100fps which feels good enough.
Will test more later.
Path tracing is in the Gamepass version, but it only shows up if you've got 12GB VRAM+
Ah that might be why then!
Had a quick google and quite a few saying the same on reddit, not sure if they had 12gb or not. Seen some saying frame gen is missing as well but it shows for me (using nukems fsr 3 mod).
Yeah it's in the patch notes for the update:
"Added Full Ray Tracing (Path Tracing) feature on supported NVIDIA video cards. A minimum of 12GB VRAM is required to make use of this feature. Please note that we’re also working to support AMD FSR in a future game update."
