WHAT??? How did you patch it?
I'm paranoid now!
I havn't had a single windows update since 2017 and nothing pending?
So what are we meant to do about this, I have run the detection tool and got this...
So all good right?
Right?
That is for a different bug (the AMT bug). This thread is for two different bugs.
Well, updated windows last night and now where as yesterday I was playing Shadow of Mordor fine on one monitor and watching a video and having other things open on the second monitor, today everything on the second monitor is crawling with insane response times listed in resource monitor and video freezing while the audio keeps playing.
With this being a systems call issue then, is task switching getting hit hard? Is benchmarks of a single application and priority going to show no performance hit but trying to do more than one thing at once potentially hit much much harder? This is on a 5820k setup.
I mean something else may have screwed up in the update as I think it did more than just the security update. I'm going to mess with reinstalling graphics drivers and some other crap but my system went from smooth as hell doing multiple things alongside gaming to absolutely unable to do this at all.
Just updated windows and something seems amiss before the update burning a 3hr video took around 4 hrs I'm currently burning a video same settings and it's going to take 10 hrs cpu is at 100% so it's full speed
Will roll back the windows update tmrw and see if it's something else but if this is down to the windows update I will have no choice but to go AMD for my main rig.
Ok what is going on here... i have done nothing to this system and yet Intel's own tool say "no problem here"
Would this tool ever actually say "yes there is a security risk here"
The date for that tool is december 2017 so i think its something else.
- Press the Windows key and type PowerShell.
- Right click the PowerShell shortcut and select Run as Administrator.
- Type Install-Module SpeculationControl and press Enter.
- If you are prompted to install the NuGet provider, type Y and press Enter, and repeat if you are warned about installing from an untrusted repository.
- With the installation complete, type Import-Module SpeculationControl and press Enter.
- Type Get-SpeculationControlSettings and press Enter.
yet as these windows patches need EUFI updates to allow them to work.
I shall report back what the Intel tool comes back with after updating.Version 1002 2018/01/04
STRIX H270F GAMING BIOS 1002
1. Update CPU Microcode
2. Improve system compatibility and stability
Well it did for me.Ok what is going on here... i have done nothing to this system and yet Intel's own tool say "no problem here"
Well it did for me.
