Edit: are you running the tests right now - if not could you copy and paste them so i can assess whether or not i've done them already - because if i have i'll carry on returning the card.
Just read your e-mail - it reads fine and informs them of all the relevant facts. My letter is a bit more comprehensive but the guy i spoke to at OC's said they only need a basic idea of the problem and your sytem spec as they will run their own checks. Furmark and crysis seem at the core of their tests.
I was just on my way to the postoffice to return mine - but i'm holding off just in case, by some inconceivable fluke, this isn't a hardware problem.
I can wait a few minutes just to be sure.
Thanks for mail - i was checking wrong account.
Below is the troubleshooting procedure I applied with all components run at default:
•Prime95 the cpu and memory - no problems
•Memtested both sticks of memory, individually and in dual channel mode - all passed.
•I have re-installed windows XP 3 times.
•Ran Furmark with just one stick of memory. But can get it working briefly if I re-install it and clear the CMOS if the system has crashed a lot but as soon as I escape a stress test it fails again.
•I have installed all the latest drivers for the motherboard and graphics card - I have even tried earlier drivers for both. I'm using 9.4 cats now.
•Tried varying voltages in the BIOS for the memory and CPU.
•Latest BIOS for motherboard.
•Increased all the fans on components to maximum.
• I've had system applications running to check all the temps. However, everything runs very cool - especially the graphics card, which makes me believe that perhaps it is the memory on the card at fault or just a fundamental error with the card.
•Tried different memory in the system.
•Checked PSU voltages using a voltmeter.
•The most conclusive test was fitting the card in another machine and replicating the same error. I did this after another forum member replicated the same result in a separate machine. This finally proved that the card was at fault and eliminated other components.
•Please see the this link
http://forums.overclockers.co.uk/showthread.php?t=17997995&highlight=plec for discussions on the problem – you will be able to see that every conceivable test was applied until we came to the conclusion the card was at fault – even though is was evident days ago.
Plec
