So far really nice here, sun is out but enough air movement to make it bearable - can even do stuff unless you are directly in the sun too long.
This is go to hospital sunburn weather for sure![]()
The irony of you moaning about people moaningWhy do some people wear coats then complain they are hot???
That's not me.
Get better sunscreen. Problem solved.Sunscreen in the eye, is there a worse pain know to man?![]()
The thing is it's not just GFS saying this and there are more and more runs saying this could actually happen!I think the GFS often over eggs temperature when the runs are fairly far out. I think it was showing 40+ this weekend through tuesday a few runs back, they ended up at our current forecast.
It's all model data, 9 days is way too far out for it to be accurate. It'll give a decent trend, i.e. it'll be dry and hot. But the actual figures are not worth looking at. As before, the GFS was forecasting 40+ degrees this weekend through Tuesday several runs back, if you had looked at it and gone, "yep, it's got a good chance of being warm and dry", then the model did a good job predicting the overall pattern, however if you saw it when it said 40+ degrees on X day, then it actually turned out to be 30 degrees.The thing is it's not just GFS saying this and there are more and more runs saying this could actually happen!
43 degrees is never happening in a million years. That’s Saudi Arabia summer heat.
Nukes don't count!Mr. Putin says carry on as you are and he'll show us some proper high temperatures![]()
