- 22 Dec 2006
- Around Town
Why?...
It should be illegal to buy air-con without buying the solar panels to power it
Look at the forecast for Kew.. first time the BBC have forecasted 40c for anywhere in the UK!It’s just getting worse…
The cool before Hell opens it's gates!Peeing down here and quite cool.
as a fresh owner of one (£200 zanussi 7000btu), from my brief search it looks like in this price range they are all similarI did look on Amazon at one with a window kit and it looked easy enough to install. I dont mind a bit of noise either.
Ideally not more than £250 or so, might be cutting it a bit thin but I'm sure there's something decent enough if anyone can recommend I'll get it ordered ASAP. Will be in the bedroom though as mum said she didn't want one.
noise is somewhere between a washing machine on spin cycle and a really old chest of freezers.
It has a compressor in it, 5-10 times bigger than regular fridge, and fan powerful enough to extract all this heat and cold.
I have mine set up in same room, need good isolating headphones blasting loud music to ignore the noise.
This is the current outlook for me in Notts and every day i look at it, it gets higher lol
The thunderstorms are the bit we want.Add a few more degrees... why not , although the thunder forecast for wednesday is gone now
They add 1-2 degrees on every morning I check![]()
That record temperature must now be 100% guaranteed to go
