Seems quite expensive considering you have only spent in the region of 8-9k?
Well we all thought it was expensive but I have it on good authority it's being sold at asking price and a deposit taken.
![Eek! :eek: :eek:](/styles/default/xenforo/vbSmilies/Normal/eek.gif)
Best get mine listed at 15k and turn a profit.
![Wink ;) ;)](/styles/default/xenforo/vbSmilies/Normal/wink.gif)
Was this done at Paul Smith cars?
You thinking about getting LED rear clusters to set it off perfectly?Looks great!
Already got them shall fit at weekend or next weekend as need to get the LCM coded.
Just dropped some rubber stops off for the boot at the bodyshop. Boot is pretty much lined up now, bit of tweaking to do and then to be painted.![]()
you gunna drop 3 grand on some apsor second hand ?
Guys
Safety question, first check this out:-
http://www.pistonheads.com/classifi...ng-e46-m3-track-car/2096725?isexperiment=true
In that advert they have fitted a reat strut brace and mounted the harnesses to it. See the advert images.
That strikes me like it might not be safe simply as a strut brace might not be strong enough but its just mounted with bolts to the top mounts I imagine, not welding. Anyones thoughts on that is it OK or a bad idea?
Very bad idea, I can't see the advert but a strut brace is not harness bar.
Keep your harnesses bolted to the existing rear seat belt anchors which will be re-enforced and have spreader plates. If you have a moderate crash the forces of your body on that bar would be in the Tonnes. Once you have a cage you can use that if it has a harness bar.
Edit: I will give you a scenario. You have an accident at speed you hit a wall hard, the force of the crash bends (or snaps) the brace bar which in turn now mean your harness is slack, If you take a second impact you are ******. A second impact could be a roll, another wall hit or another car. Safety Items really are not something to skimp on, as I said before A harness without a cage (albeit better than a cage without a harness) is more dangerous than no harness
On another note, WTF are Hexagon smoking!
What are you using for the overlay in your videos Gibbo?
Were the LED lights hard to get coded? I don't really understand what was required there but would love the LED clusters on my E46 as I can't stand the non LED ones.
