What happens is EMI/RFI gets into an audio device via the ethernet, another way is the power cable (even more critical). That EMI / RFI gets into the analogue stage of DAC's, it can also effect timings in clocks. This is why all the high end DAC's and higher sound cards they focus on reducing this noise. For example the Asus STX II has improved noise filtering over the original Asus ST /STX range. Now the argument against using any additional ethernet filtering is that ethernet ports are galvanic so there is no need for any additional filtering, if you look at the link I posted above someone has measured the noise on Ethernet cables, it's clear regular ethernet ports don't isolate all noise.
The following is the cheap way of reducing the interference, it's Amazon Basic's cat 7, there is a galvanic voltage isolator, wrapped in aluminium kitchen foil for shielding. Below has cost me little over £30, about the same price as half a tank of petrol. I can confirm that this improves audio. All cables are aerials, and the Amazon Basic cat 7's are well constructed with good outer braid.
Hans Beekhuyzen is talking in this video about an £1800 ethernet filter and why it works, however you can have the £30 solution above.
www.youtube.com
This chap is also talking about his experience with noise from ethernet switches.
www.youtube.com
You can have a joke at this post, however if your running a good DAC or streamer via ethernet, almost certainly there will be EMI/RFI entering and degrading it's sound.
Network Acoustics Muon Pro Streaming System ethernet filter
This is the third time I review an ethernet filter by Network Acoustics, specialists in digital audio connections. Did they again manage to improve the sound...
- YouTube
Enjoy the videos and music that you love, upload original content and share it all with friends, family and the world on YouTube.
