Caporegime
- 8 Jan 2004
- Rutland
This has not been proven. The claim is marketing not science.When you reduce the noise you increase the detail.
"When I plug in my ludicrously expensive cables and listen with a totally unbiased ear, it definitely sounds better"
That’s the problem - only a few people can admit that the expensive thing doesn’t doesn’t deliver. Things should be measurable with the right test (to the ear) however inside peoples heads may or may not actually be measurable.
Sound waves are measurable. It would be very easy to analyse the actual difference all these things make. Curious that the industry relies on subjective airy-fairy 'feels' rather than quantifiable improvement.That’s the problem - only a few people can admit that the expensive thing doesn’t doesn’t deliver. Things should be measurable with the right test (to the ear) however inside peoples heads may or may not actually be measurable.
I did not believe it also, until I tried some. I use RA super fuses, paid £95 for 5 they are worth it.
We have got some tools out there - there’s even a free linux DSP that will solve the room issue quite well (you’ll need a mic for calibration).
IIRC it’s call CAMILA or something.
Well done!! You certainly fooled us. For a long time most of thought you were serious.
Now with this statement about fuses we know you have been trolling us all along. Well done for keeping it going for so long.
Because nobody would be gullible enough to believe a fuse could make a difference to sound Quality.
I can only imagine the laughter in their office whenever they sell one![]()
EQ cannot fix room issues, it can only mask them at the calibrated listening position. A DSP that uses spatial tracking to adjust based on the listeners position in the room could be interesting. Still won't be anywhere near as effective as fixing the room issues in the first place though!
Imo it's hard to do a proper, accurate test at home. Unless a speaker is connected with cables/fittings a, then another with a different setup so it can be quickly flicked to that one. In reality, by the time you do these changes its probably 30 mind, and you've just spent a large amount of money on stuff, of course it's going to sound 'better' (can't remember the phrase but its the placebo effect with a fancy name), but obviously this is subjective and probably just sounds different (or maybe even not different at all). Reducing noise is good, but imo if your noise is already low (which I'd imagine most setups will be), you will only see it on a scope, but won't hear a difference."When I plug in my ludicrously expensive cables and listen with a totally unbiased ear, it definitely sounds better"
Not to mention most of the people who have the income to afford all the audiophile snake oil are older and their hearing would have lost sensitivity due to age so definitely won’t be hearing real differences.
This is a Wattgate 350 EVO RH, they make a better connection with the IEC connection.
This is over £140 retail for the wattgate separately. This is connected to a Powerkord 300.
This is the inside of an older RA reference cable plug. You can see the 8 live and 8 neutral copper cores, each core is high purity copper with kelvar dielectric. It's the twisting of these cores in a weave that reduces EMI / RF entering the component. When you reduce the noise you increase the detail. The black fuse a RA super fuse.
The component you see between the neutral and earth is part of a clamping device, and was NOT added by Russ Andrews and added after the cable was sold.
The entry level RA Yello powers are a significant upgrade over a £5 standard power cable. However a cable such as the RA Powerkord 300 is again a significant upgrade over a RA Yello power.
Also that shielding for the cable is basically looking like it's touching neural.. I would expect the shielding for the cable to be grounded..
