Thanks Carl
This is from 8th October, forum wasn't loading for me at the time.
I since officially quit competition modding not that I ever did any other than get nominated on bit-tech, many reasons why, everyone has their own idea about what modding is being the main 1 & how it should be done & I got tired of petty BS but love modding still so onwards I go as a completely uncompetitive modder.
I needed to get that out of me so it would stop bugging me, grinds against creativity being negative which might have made me actually go & rage quit modding if I kept on tolerating it lol.
So uncompetitive but definitely continuing the craft but without any BS interfering with my thoughts which will be nice.
On with it then.
I changed the optical cover to use a 10mm plate for a cleaner look.
Making the edges perfectly flat by filing & using the disc sander.
Applied the top & bottom templates.
Drilling nearly all the way through the optical plate leaving about 2mm as an alternative mounting point since I changed the design slightly.
Had lots of tapping to do in this session.
This is a sweet method for drilling exactly where you want to, 3mm hole, 3mm drill bit, give it a tap with something & it leaves a nice mark for drilling, just as good as drilling through a stack of panels.
Here is the 6mm hole I drilled which leads to 2mm depth 3mm hole for alternative mount point.
In place.
Fixed in square bars & round bars, used m3 grub screws in the round bar that go straight through the panel & into the square bars & then marked & drilled countersunk holes to fix the round bars.
Cut some 10mm round bar with hack saw, made the ends perfectly flat on the disc sander, drilled, tapped & added grub screws so they go through the panel & into the optical plate.
I called it a wrap at this point, think I started at about midnight & finished up around 4PM, was knackered.
So that was a bit ago now but been flushing the negativity out of me by having some fun since & now I'm set to get back onto this.
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
