Wow. I've just spent the last hours reading through your log from start to finish - I'd no idea how long you've been building this for - seeing how it's come together it's no wonder this has taken as long as it has.
First of all, I'd like to congratulate you on the job done to date.
When I first looked at this, I thought the the design is not to my taste, but after reading, I'm absolutely blown away with the detail - that it what has won me over.
Your dogged determination and perseverance is just amazing, as are your use of tools in this build. You've not got one of those "new yankee" style workshops, but a few important tools, and my god you know how to use them, and have the patience to get the finish you are seeking, from them.
Love the Spinner thingy, and the write up of the Zalman failed smooth base. A lesson learned for the community...
For once, I'm not actually that interested in the hardware inside the box.
One of the best builds I've ever had the privilege to follow.
Subbed, and thank you for sharing - You must have spent half the build time documenting this for us!
Thank you very much Tattysnuc, appreciated mate
![Cool :cool: :cool:](/styles/default/xenforo/vbSmilies/Normal/cool.gif)
I have been told by some I should invest in some rendering software to represent my designs better but ouch, they are expensive
![Big Grin :D :D](/styles/default/xenforo/vbSmilies/Normal/biggrin.gif)
would make things look a lot more pro but I kinda like the cartoony effect the sketchups have because when the real piece is made it looks a lot better if done well
some do amazing rendering & really bad modding, glad I've got things the right way around,
I don't really need them personally but yeah for showing others how I see the designs closer to how they would look in reality, the scetchup raw models don't cut it for most I think, but I'd sooner buy new tools than software I don't really need & I think it would spoil the surrprise of how it looks in the end.
All the teeth marks or most of them at least & surface finishing I'll be sanding smooth so the looks will shoot up again when I do that just before I send everything to be anodised.
Had to do some extra planning the past few days gearing up for a mega hectic November of none stop modding.
Pedestal
Pricing of MDF & plywood at local DIY stores is a bad joke unfortunately.
18mmx1220x2440mm MDF £18 or plywood £29 but I'd need a big van to transport it, this 1 piece covers what I need so this is an annoyance plus I'd rather use 25mm thick but they don't offer it.
6x 18mmx1220x606 £93 in MDF at £15.50 each & £221 in plywood at £36.82 each, plywood at half the size near £8 more expensive LMAO yeah that makes sense.
Veneer on top about £25 for each flavour so between £150 & £300 so too flipping much, so wood work is officially an insane choice of material for me.
So now I know I should just make an all aluminium version
would be far cheaper & lighter weight too, flipping heck the amount of aluminium I could order for the cost of that basic wood LMAO, it's an absolute no brainer.
Bars & sheets of aluminium simply making the aluminium order a little bigger, biggest challenge will be making it not resonate any vibes but yeah it will be a lot cheaper than using sheet wood & veneer & instead of nice looking woods I'll just make it nice some other way, plus making it as a frame & covers it will be very highly moddable in the future, think it might actually be nicer too.
So I'll just work the design change to see what material I will need, add them to the order I was going to do for extra materials I need to complete Lean & green, get it ordered with some spare bits to hopefully cover extra bits I do making it up as I go so I won't have any delays running up to the deadline & get extremely busy, gonna need a new screw order too, there will be many used on the pedestal & it has to be as strong or stronger than the one I designed but it will be lighter.
Lean & green, main current topic.
Worked out a design to make the joining cover nice & sturdy between the 3 pieces, it's a mix of 15mm acrylic & 3mm & 5mm aluminium rods, the curve & bend panel won't be fully fixed on until it's been anodised though because it's fixing on permanently with JB weld but the cover piece will be removable, just the cover will be stuck to the frame support.
Ordered & received 5 shades of silver metallic, black metallic & green metallic, white plastic primer, white primer, 2 cans of clear & worked out the paint job I'll do on the plastic fan blades, the blades on the akasa venom are quite different to the ones pictured in the model & will be a bit of a challenge to do this nicely but very much worth the effort.
2 of the shades of silver seem really similar so I'll have to do a faint quick haze of the darker ones for 2 of them so they work as intended together.
I had to do this bit of extra planning ahead to make sure the materials are here & ready for when I get to later stages else I wouldn't have a chance of making the deadline, November is all out gogogogo, fun times, but don't worry about it being rushed & compromised, it won't be, just the volume knob of dedication is going to crank up to maximum, big difference between rushing things & just applying yourself properly.
