Had a huge session starting yesterday & finished up at noon today, was well in the mod zone to go on all day but had to go supermarket, it broke my flow, came back ate some food, was just about to get stuck back into this but after setting things up to continue my senses must have dulled rapidly, yawning my head off with sloppy hand eye coordination, made a coffee & a tea for my dad I knocked the full fresh hot cup of tea on my crotch lol, I took it as a clear sign to not continue modding today or I would screw something up badly, luckily I was wearing thick jeans & it stopped me from getting burnt but it looked like I peed myself, oh well.
Getting the rods to exact tight fit, took a while.
Then started taking it all apart to add the mounting holes for the rods & to take some material out so the revised HDD cage covers look better by not showing the ends of the bent covers.
Then a hefty load of drilling & tapping, showing the 5mm rod I drilled & tapped for m3 screws here, this shows how awesome that rod drill helper is being able to do this, pretty amazing DIY tool I think but drilling the longer rods was more difficult, had to use my square to make sure I was drilling square.
Other bits I did but didn't take pictures along the way, was focusing on progressing more.
Rounded the edges of all the 10mm plates, removed the teeth marks on the power switch piece using the new detail sander, took apart the power switch piece a few times to shorten the width so it would fit in with the rods.
The 3mm rods I couldn't do where I did the mounting holes so I'll have to carefully move the 3mm holes forward a touch or buy 2mm rod but it comes on coils so would have to make it perfectly straight so I'm going to try moving the holes forward 0.5mm, as long as I do it with extreme care it should work nicely still.
The rounded edges, 5mm & 10mm rods installed using countersunk screws & grub screws for the level change, good & solid.
I am aiming to get the HTPC done this weekend though & when I say done I mean the main structure completed, not the finishing touches like cable management holes, edge & surface finishing, I'll likely wake up during the night & get back onto it & try to have it done by the end of Sunday so I can start on the gaming rig on Monday.
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
