I'm glad I'm removing all dimming problems!
Thanks for all of your help, it's been really useful, now to find light fixings!
What to do with them though? It's too many to have hanging around as emergency spares, and they're not worth anything.
They are 40W
They are recessed into the ceiling as spotlights, but they seem to be small screw type fittings.
Will take a photo when I get home this evening.
Depends what's above your ceiling. GU10 fittings need air around them to dissipate the heat. I had to use loft insulation support boxes to create an air pocket for them. You could also switch to a standard light fixture.Would it be a big job to replace them with GU10 fixings?
Those light fittings will obviously need to be removed and that transformer would need to be swapped out for a 12V one.After some advice. Got this in the kitchen just now and the bulbs go all the time so fancy moving to led. Is there an easy swap? I also wouldn't mind getting an led strip if that would be easy to do?
Don't think you can. Unfortunately there aren't proper equivalent LED bulbs for every fitting. I've recently replaced 4 light fixtures that took those horrid capsule bulbs, partly due to that reason.Anyone know where I can get some standard sized G9s of a similar wattage (4.5w)?
uncle_rufus;26847786 [snip said:2. I can't work out how to get the existing bulbs out!!! Sounds stupid I know but other houses I'm used to having like the exposed face of the bulb flush with the mounting in the ceiling, and a little wire sprung piece in front of it that you squeeze to remove and lets the bulb drop down... These ones appear to have that, but over the top of it is like a more pronounced chrome shroud with a secondary bit of glass/plexi type stuff. I've tried twisting it to see if it unclips/unscrews but I don't want to put too much force into it and break it if that's not how you get them off...
Any ideas (hope I'm explaining clearly enough!)?
They aren't very bright at all for 5W LED bulbs so guessing old tech. 3000k is not true warm white either.
