OCT20
This is 20% off over all, just did £220 odd worth for £174 delivered.
I went ahead and fitted just the 4 and with the day light 4.5w LED
http://www.ledhut.co.uk/spot-lights/gu10-led-bulbs/new-4-5-watt-gu10-led-350-lumens.html it's mega bright. Looks clean. I fitted the lights with the cable and then into 1 J501 Hager (Ashley) 17th Edition Junction Box 16A. The original feed that was into the ceiling rose then went in the other end of this box. It was fiddly but I know its safe. Going forward will look into the Wago stuff. Anything more than 4 would bee to much for a room that's 3.1 x 4.1m.
Today I replaced the kitchen units. The holes were big and a mess. I used my largest still to get straight lines. With the help of the boss (her in doors) one end was on the edge of the current hole and a line drawn on the other of the still. Lines then draw ether side of the current hole and the center then measure and marker. The new center hole was 70mm over which gave plenty of space. 6 new holes, 6 new down lights
http://www.toolstation.com/shop/Lig...+Fire+Rated+Downlight+Fixed+GU10+Mains/p13444 There was daisy chain already fitted with T&E so I use the chock blocks and boxes already present. Just add 8'' of T&E to the light, drop the current cable in the new hole then wire in. Super easy and so much better. As above have order some cool white for the kitchen.
So far have fitted 22 downlights... hallway, upstairs landing, downstairs toilet, boys room and kitchen. All have 4.5w GU10 LED and all are the Sylvania Fire Rated Downlight Fixed GU10 Mains
Now the front room. 6.8 x 3.4 m. Thinking a total of 10 but want to do a nice pattern I think. Any ideas?
