- 18 Feb 2007
- London
np just edited last post with 2 pics of lights you can sort of see how they look
Brilliant thanks
in the bathroom there just so good worth ever penny and you wont want any other bulb .Brilliant thanks, look OK so might try some in the bathroom or extension.
Cheers, not really wanting a clinical look in the dining room, think I will stick with warm white then.
Homebase are selling off a load of LED GU10s at the moment. I picked up 38 bulbs for something like £38 on Sunday. £1.93 per pack of 2.
Are they these ones? http://www.homebase.co.uk/en/homebaseuk/tcp-led-gu10-non-dimmable-bulb--4w--35w---2-pack-194014
They look like that have a very narrow beam - more of a spotlight?
I recently changed the old 12V halogen under-cabinet lighting in our kitchen to some 5630 LED strip (from ebay). The LED strips themselves are great, however I'm less convinced with the LED drivers which came with them as switching on the lights (which come on with the main ceiling lights) randomly trips the MCB on our consumer unit - probably once in every 20-30 occasions.
A bit of research appears to indicate that a lot of LED drivers have a high 'inrush' (i.e. current surge at switch-on), and can trip a 6A Type B MCB - particularly if multiple drivers are used on a switch (my installation has two).
The drivers which came with the LED strips are definitely el-cheapo (laptop charger-style) ones like this:
http://www.thehunthouse.co.uk/images/LED_driver.jpg
** Please don't hotlink images **
** It's not hotlinked - that's a stock image uploaded to my own webspace...**
I could probably resolve the issue in by getting a sparks in to change the MCB to a Type C, but as an alternative, can anyone suggest some better LED drivers which are don't have a high inrush?
Anyone able to offer a little advice for an idea I've got?
After getting LED lights of some sort put in the bathroom last year I've been wanting to change the lighting in the dining room to something similar.
The lights in the bathroom are a fairly bright/harsh colour which probably wouldn't suit for dinner but I do rather like that lighting for playing boardgames!
Is it possible to have some sort of switchable LED that can change between temperatures? Or would it be easier to install different bulbs in different fixtures and run them separately?
That probably sounds better in my head but hey ho![]()
Just installed some Aurora M10 units in my bathroom. Honestly the closest to perfection I've seen in an LED - plenty of options for colour temperature, features, bezel colours, beam angles etc. And you can buy a trimless option which always looks fantastic. They come with a great connector as well so you don't need to buy a bunch of boxes to wire them up.
Worth every penny. My new go-to option, replacing Photonstars offerings.
They're quite expensive, but LIFX lamps will do what you require and more! They have launched some GU10 variants but I'm not sure how accessible they are in this country at the moment.
I'd assume there are comparable products out there, but unfortunately I am not aware of their names!
