I would go a bit bigger rather than running it at capacity all the time.
Hey guys. Quick question to all the led bulb techies.. How can I tell if my light fittings will power led bulbs? I got mr16 spotlights. About ten of them. Can I buy one bulb to test if it works? Then buy more once I know it powers up? I'm gonna place an order with ledhut, but I don't wanna buy ten to find out I need a transformer to go with it
Edit. The house is a new build, and the kitchen already has 15 gu10 led bulbs in place. So in theory the whole house should be led ready?
Thanks, I was thinking warm white but just wasn't sure what wattage to get as ledhut have quite a range with some new bulbs as low as 4.5w.
I might start of with just a few to see how they are, what would you guys suggest preferably from ledhut to light a largish staircase/hallway ?
I have two lights in this area, one light covers a biggish area and another a fairly small corridor.
thanks
I just wasted a bit of money buying a strip of LEDs to go under my kitchen work tops. I wanted them to replace the existing tube lamps, they do not produce enough light.
This is what I bought. Ill likely find another use for them so cant really say I wasted the money.
https://www.ledhut.co.uk/led-strip-...roof-led-strip-lighting-kit-5-metre-roll.html
So I don't make any more mistakes money id like some advice please!
I've looked at these
https://www.ledhut.co.uk/led-strip-...arm-white-best-price-on-the-internet-237.html
Are they likely to give me enough light to work at the kitchen tops when they are on? Do I need a 36w psu to power them i.e. the one linked below or do I need more output from a psu? Ill need all 2.5m to be powered.
https://www.ledhut.co.uk/drivers-fi...nsformers/36-watt-led-transformer-driver.html
I never really paid attention or carried out my own research to the bulbs the electriction installed for me. These are the bulbs I currently have, I managed to track down replacement bulbs - http://www.amazon.co.uk/gp/product/B00AZFAF6Y/ref=s9_simh_gw_p201_d4_i1?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=desktop-2&pf_rd_r=10C49TMJQBKS6K780QZW&pf_rd_t=36701&pf_rd_p=577047927&pf_rd_i=desktop
What I'm looking to find out is wither these are any good or are they just cheap and nasty? Would I be better to replace the lot with these GU10's from LEDHut - http://www.ledhut.co.uk/spot-lights/gu10-led-bulbs/new-4-5-watt-gu10-led-350-lumens.html
Am I right in thinking that the GU10's from LEDHut will give me a brighter and wider spread of light, compared to what I have this now?
