Philips lamps are excellent. Screwfix do them for a decent price.
and (to my eyes) indistinguishable from Screwfix bulbs
Screwfix Cool white have a year longer warranty
Right I've tried in addition to the Philips "Master" an Osram and another Philips LED.OK - Fitted a Philips 10W MASTER LED (60W Replacement) Warm White, Dimmable, B22 Bayonet Cap bulb in a bedroom.
It's controlled via a Varilight JQP401W LED Dimmer Switch.
I've noticed from 2-3ft away I can hear the bulb buzzing. It's not loud, but it annoying.
Is this normal? Or is the bulb faulty?
Anyone able to recommend a B22 (Bayonet Cap) LED replacement bulb that does not buzz?
am i right in thinking that i need an LED driver to replace the aurora?
Used LEDhut a week ago for some GU10s for the kitchen. So much brighter and I cant believe 6 bulbs are only taking 30 watts compared to 210 watts before. 4000K gives off a lovely white light too. Not too blue. I got the wide beams and I was a little skeptical about there being bright spots, but no, they give off a nice even light.
They have a very slight green tinge but it's very difficult to notice it's still a very white light. Shot some gray cards with my DSLR and analysed the raw output. Green channel is about +1EV relative to red and blue, which are even. But I guess that's to be expected at 4000K.
I think plants look really good due to this.
Now looking to get some 4000K bayonet bulbs for the stairs/landings too.
RE B22 (bayonet) see my post #1866...
Did you have a link to what you purchased was it this
Philips LED Warm Glow B22 Bayonet Cap Dimmable Light Bulb, 8.5 W (60 W) - Warm White
these ony seem available in 2.7K and not 4K.
asim18 if you want a colour accurate 4k non-dimmable the hyperikon colour is great, only issue is they may interfere with FM radio, but since it is amazon you can retrun them.
.. wait until price drops again to £12.
Buckster;30484544 said:Anyone else find they are not very reliable ? Sort of defeats any cost savings
I replaced most of the CCFL ones in our new ish house 2 years ago
So far 5 LE branded ones (not cheap) have failed (these were fine for 18 months then started failing at rate of one every 2 weeks to 1 month)
Replaced some of these with Philips ones recently - 1 has failed already
Bought 5 OSRAM M9 halogen replacements one has failed after a month
Bought 6 Ever ready mini globe E27s none have failed but I have had to remove 2 as they sound like mosquitos
Is in general the quality not what it should be or do I have dodge light fittings/electricity !!
I deliberately picked well reviewed price not an issue bulbs for all of above with hope they'd last
Only ones that haven't failed so far are Integrals but I only have 3 of those so smaller sample size
I noticed most LED bulbs have life hours specified and switch on cycles specified .... well to me that is a bit of a nonsense
its all very well having a LED life of say 50,000 hours, and say 150k switch cycles - BUT if the random failure rate (which is separate to the "life" and takes into account the random failures of the LED, the power electronics etc) is say 10,000 hours, there is a very good chance that most of the time you will never reach the "life"
BigBoy;30484776 said:Considering the volume of lamps you are getting through I would say you have an issue in the property, I fitted my entire house with LED lamps (bar one lamp that has narrow glass shades) nearly 4 years ago and only had one lamp die.
All lamps were from LEDhut or screwfix.
