Any tips on an LED strip to light the inside of my shed?
I got a 6m run of 3528 LEDs with 60LEDs/meter which was just far too dim to be of any use.
Is it worth trying a strip of 5050 LEDs or should I just get a 30W 6ft batten? Have a 70W batten currently which is ok, but ideally the LED strip would help to light up the dark corners.
Screwfix MR16's are good (indistinguishable from Philips)
fitting would make zero difference.
different brands of bulbs however use different tech. there is a standard in place though and some other brands are compatible with the hue hub.
LIFX for instance doesn't require a hub at all.
Has anybody got any recommendation for an led pir security light thats IP67 rated? Struggling to find any so far.
What wrong with IP65, or do you plant on putting it in a swimming pool.
https://www.ledhut.co.uk/led-flood-...ine-led-flood-light-100-watt-replacement.html
It just looked as tho most seem to be 54 which seems a bit low. Thats exactly the thing i was looking for. I had a look at wickes and most seem to be around 600 lumens which seemed a bit dim to me.I was looking at the security/flood lights and notice those ones are hard wired. Are they all like this?
Well the ones with PIR would run out of batteries frequently. How else do you imagine powering them?
Drill a hole and run them off the nearest socket.
I use a solar powered PIR light, been brilliant so far, lights up the back garden enough for when we need to go in the garage.
I bought a 4 pack of Ascher G9 bulbs (warm white 2800k) from Amazon back in April. I used one to replace a halogen bulb in my desk light which liked to blow every now and again.
It does the job, uses 5watts instead of 35/40w. The light colour gives my spare bedroom/computer room a nice feel in the evening and it doesn't pump out a ton of heat either.
Never heard of the brand, but they work.
Two questions:-
Regular Bayonet
Anyone able to recommend some replacement for regular bayonet cap bulbs? We have three 60w bulbs in our lounge that would be nice to change over to more efficient LED ones.
They need to be dimmable, ideally without me have to replace the (conventional) dimmer switch?
GU10 Spot Lights
I have seven 50w GU10s in a playroom and four in a study.
Can I replace these straight over to LED versions, again running off conventional dimmer switches? Or would I need to replace the dimmer controllers etc?
Or in all these cases do you need to buy dimmers specifically for LED bulbs. We have such a situation in our bedroom and I recall actually programming the dimmer so its range was "correct" for the bulbs and could dim them down to a nice low level...
Does it matter if you run LED's and Halogens together in the same light fitting? Going to compare some bulbs.
