Yeah tried for a bit, hard to tell if it helps as I’m usually already feeling it by then, and can’t reach the keyboard and mouse when I do so can’t do it for too long while working
Am assuming viewing distance is definitely a part of it, as with my CX 55 in the living room from the sofa I’ve never felt it at all.
Just surprised the feeling is so dramatic, been hooked on screens my entire life..
Looks like Dolby Vision IQ is just ambient light adaptations (with metadata). Only works on compatible content so first check for content that is known to have it.How do you activate or get Dolby Vision IQ working? Watching Dolby content (Witcher) but there is no option or am I missing something obvious? Want to give it a try and see how that and the "Precision Rendering" aspect works.
There is big difference 1440p is 2kespecially if I'm sat back with a controller it can be hard to tell the difference between 1440p and 4K once you're back far enough
maybe your sitting to close to it! Do the same with your other OLED in LivingroomAnyone ever gotten a nausea/motion sickness feeling when you’ve switched to an OLED as a monitor?
No, 1440p is QHD, 1920x1080 is (effectively) 2kThere is big difference 1440p is 2k
maybe your sitting to close to it! do the same with your other OLED in Livingroom
I'd hope for a setting in the TV but maybe not?
I think you have to set on Cinema Home picture mode that switches on DV IQ, but you do have to do some extra settings for it.
He says its best to use Cinema home/DV IQ when you are watching in a bright room though due to the light sensor and in a dark room just Cinema mode.
You need to run a DV source to set up the right settings also.
Commonly and wrongly2560 x 1440 pixels. This resolution is also commonly referred to as 2K most people don't call 1080p 2K; they call it 1080p or Full HD
Could it be possible there is first & 2nd batch OLED that gets released in a year! April is the first batch C2 oleds that was ordered by some online retailers had older/new panel issues but still got sold without QC in the mad rush to buy them, maybe the 2nd batch later this year OLEDs might be fixed? Or the software get released! It was the same with the 55CX in April 2020 with crushed blacks & grey uniformity issues that put me off but later in September 2020 the 55CX didn't had those issues not for me anyway and it could be where you buy it from as well been a panel lottery imo.Yes someone did get back to me it is crushed blacks issue that I have as you say, he did attempt to advise me to try some settings to fix it (white balance points) but I could not find those exact settings. I will have to keep digging and asking till I get some concrete answers, its quite possible my 42" C2 is faulty, I can't imagine black scenes would be that bad and pitch black but they are on my screen and maybe upping the black level a bit is not a good fix but no one else has confirmed it yet. Got 3 more weeks to figure it out at least. Its a shame it was the flicker that was causing your headache, but sadly it does something effect some users they really do need to address these issues.
3840x2160 recommend but you can set it to 4096x2160 in TV if you wish but will you see the 256 pixel defences!, There is no 2.5k for argument sake 1440p/1080p frequently called 2K don't take my word for it google it and there is no point going 1440p on this OLED for higher frame rateCommonly and wrongly 4k is a cinema resolution that partners with UHD; 4096x2160 in cinemas and 3840x2160 on your TV. 2k is a cinema resolution that partners with Full HD; 2048x1080 and 1920x1080.
Just because everyone says it doesn't mean they're right, QHD does not have a cinema equivalent and if you really must you should call it 2.5k not 2k. It's a boring thing to argue about but it's facts *shrug*
I disagree with every bit of that post, you're wrong, so are the many examples you found in Google3840x2160 recommend but you can set it to 4096x2160 in TV if you wish but will you see the 256 pixel defences!, There is no 2.5k for argument sake 1440p/1080p frequently called 2K don't take my word for it google it and there is no point going 1440p on this OLED for higher frame rate
Yep result it is.So basically got a better TV with the latest Evo/EX panel and saved £100s
result
No, it's likely not because of OLED. Completely disable all the motion related settings like TruMotion, they are the cause of our issues. The first day when I had the 42C2, I literally got severly sick within half hour. I couldn't bear it anymore. Next day some users here, I think R3X, advised me to disable all of the motion nonsense and indeed, it worked. No more nausea. And it also helps to have the HDMI set to HDMI-PC which improves the colors and less 'biting' the eyes. Picture gets smoot which is easy on the eyes. Once you do that, nausea/motion sickness should be no longer an issue. However, if you still have fatiguing headache, the chance is there you might be sensitive to flicker like me.Anyone ever gotten a nausea/motion sickness feeling when you’ve switched to an OLED as a monitor?
Had my 42” for a few days now using it for work, and get a noticeably nauseous feeling fairly quickly after I start using it. No headaches as such.
Got a new bigger desk on the way as I am definitely too close currently (60cm deep desk), so could very well be that since I’ve never had it with my CX living room TV which I’m much further away from.
But just concerned it could be something else.
Have colour temp on Warm 50, and lowered OLED brightness a decent bit. Also use dark mode for everything. Might try some extra blue light filtering while working too.
Also read up on bias lighting so looking at setting some white light strips up behind it too.
But just curious on everyone else’s experiences when they switched. Or maybe not OLED related at all, maybe to a bigger size screen, or stronger contrast screen, or something.
I was concerned about that. I mean, I couldn't see crap in GTAV/Online when it's night in the game and some missions are stealth so I don't wanna miss the targets or shoot the gastank by accident in heist setups.Yeah that is my exact concern, getting greyish blacks obviously you lose out on those inky blacks.
I still have very good blacks but they are a tad grey now, maybe its an fault or fixable with tv calibration or better settings although they did say the LG was meant to be excellent out of the box, clearly not for some though.
This would be quite a pickle since there is nothing on the market remotely close to this LG 42 C2, maybe the Sony will be better.
When watching Netflix, picture is excellent but...it is a bit of a problem because of the crushed blacks.
If Sony will be better and they finally improve the inputlag, I might get one. But it will HAVE TO BE worth the price! But I'm afraid about the aggressive ABL, that **** is really noticable.
Or it is you got it wrong but won't admit it! So also you're saying you can't change the 3840x2160 to 4096x2160 on the OLED Resolution! the TV can only do 120hz so how can you do 144hz @1440p please show usI disagree with every bit of that post, you're wrong, so are the many examples you found in Google
The thing is you can Google anything and find evidence now. Humanity had a great opportunity and ruined it
Yeah this is why I was worried I had a faulty panel, but the 3 guys I spoke to said they had similar issues with crushed blacks so just upped black level to 53% gave it a good month use or 100hours and more, then set the black level back to 50% and the details appeared.
I am hoping that happens with my case, if not its going back.
I think though its important to give these OLEDs that 100 hours+ or 3-4 weeks good usage before checking for these faults, these OLED pixels really do need charging up almost.
The Sony 42" could still be interesting, especially its thermal feature to get more brightness but yeah don't think they will have improved the lag or gaming side here.
