- 8 Oct 2020
Set Gaming mode for picture mode
go into the Home label PC input as PC (disable extra stuff too)
set HDR on in windows & maybe calibrate game mode to your preferences (brightness etc)
thats it
from another user of one I would lower that TV I had mine that high & got neck ache, wlower by 3 inches at least.
but give it ago you ll see
doesnt happen for me,Figured it out. Seems to be if it drops below the Gsync cut off of 41. Screen goes black for a second then it comes back on. Love to know if there's a fix for this as turning off Gsync isn't ideal.
Buy the mount you plan to use. Then measure it and calculate the height you need (i.e. how far up/down the TV are its mounting holes. Then how far above/below the mount do its mounting holes appear, do some maths then drill).How do you mount your TV's to the wall to the correct height for your desk?
That's the nature of reviews really. People most likely to leave a review are either really impressed or really upset. RS and JL have good reputations and also pretty good policies in general. I'd go with them over a small supplier who might be harder to chase up, if the price difference was small.usually either REALLY good or REALLY bad experiences with nothing inbetween.
Is that setup in your garage? I can't unsee the car doors over there lol
it used to
However since then
updated drivers of nvidia
had like 12 LG patches (firmware updates)
since then its been solid
only other thing to check is ensure HDR is on in desktop
had it where in games it switches between HDR/SDR & black screens. force HDR stopped few black screens
OR
Double check your HDMI cable has enough bandwidth for 4K 120hz
BUt definetely update your LG firmware theirs been multiple fixes for gsync & black screen
I'm on 04.30.10 i bought this tv on 02.35.0
Its Menu -> Support -> Software update
Ive never wall mounted a tv/monitor and as I'm considering doing the same as Sleepy_Stu (plus others) Im afraid of drilling holes in the wall only to have put it too high.
replied to your trust i believeHDR is always on on the desktop,I have it on use HDR and Auto HDR as well.
TV is fully updated.
Vsync in in NVCP and instant game response on the TV activated.
Ive tried a few HDMI cables now but Im curious, what cable are you using? I have tried 3 or 4 at this point.
Also Ive read issues can occur with game response if sound is set to optical/tv speaker. Changed it to speaker to see if that matters.
try turning off amd premium freesync, i notice this also when got the latest update, when playing warzone in the matchmaking lobby my screen would turn black no signal and never comes back and i need to reset the pc , this one solve my problem and when i check the hidden info it now says GSYNCFigured it out. Seems to be if it drops below the Gsync cut off of 41. Screen goes black for a second then it comes back on. Love to know if there's a fix for this as turning off Gsync isn't ideal.
@TheOracle looks neat, so how far away are you sitting from the screen?
Really tempted if there's a deal on between now and xmas to pick one up.
I pulled the trigger and set up my 48 OLED today!
First impressions is it looking amazing on desktop alone, not yet tried to game as been fiddling with settings.
That said, whats the recommended settings to change in Windows and the TV itself?
Ive hid the start menu but I can still see the top of the search bar, is there a way to get rid of that?
Also is there any HDR settings which dont burn my eyes out or is turning on HDR in windows not nessacery to use HDR in games?
Thanks for any help!
