- 5 Nov 2005
Wow thanks for all the details!! Well now I just need the 42inch to be released!!
Just played a bit of fifa with my nose right up against the screen to really see the difference. It's not as big a difference as I thought. 1440p is only a tiny bit smoother than 2160p. If you are sat back in your chair, unless you have both TVs next to each other, I'd be surprised if you could tell to be honest.
Yes, 1440p is smoother, but only a little bit.
Hmmm thought I was set and then I watched the Linus YouTube video on burn in.....not sure how much of any issue to it is? Assuming I will be ok with just 3-4 hours of gaming and web browsing a day? Any tips? Assuming screensaver and hiding start bar?
I have a oled TV for normal films and TV with no concerns...
The C1 is very bright for a start. I have turned the OLED screen down to 15 which is still plenty bright enough. I'm also using translucentTB from the MS store which makes the taskbar translucent (looks really good).
Mines on the desktop hours a day for work, and I also use it for gaming. Not seen the slightest hint of either burn or retention.
I guess if you run the thing at 100% HDR and leave something on the screen overnight things might be different.
It's one of the best things I've bought in a long time.
He's just a prat, ignore him. I haven't seen a single other report of OLED burnin on 2020 or 2021 models. Sure they're only 2 years old at this stage but still, you'd think more would be failing than just his.Hmmm thought I was set and then I watched the Linus YouTube video on burn in.....not sure how much of any issue to it is? Assuming I will be ok with just 3-4 hours of gaming and web browsing a day? Any tips? Assuming screensaver and hiding start bar?
FTR I must have 3000 hours on my CX now and never modify any display or Windows settings. Stock desktop, no screen saver. I just don't have the brightness up all that high.
Yeah I do agree there - I think probably all OLEDs will have a lifespan of significant degradation over time. Whereas more or less all LCD TVs and monitors I've used basically performed the same until something else caused their demise. I do think that the useful lifetime is long enough to justify the picture quality though. Then I'm a very mixed user, it is primarily a TV for me, which does a lot of PC gaming and is my personal PC (so sees a lot less use than my work screen).The thing is, for normal (mixed) usage, it'll probably be fine for a number of years; BUT if you're a heavy user or do long runs it will begin to become an issue all the more sooner; its just how much you notice and how soon; there is genuinely a limited lifespan on these panels. You CAN get it on LCD, I have it on one that is around 7 years old; but they are less susceptible.
Got a message when I turned on CX today saying it wants to start screen restoration to improve picture and will take about 5 minutes. Not seen that one before...
Seems to be referring to the 5 min pixel refresher but I thought it would be doing that automatically during standby.
But do you get an on-screen popup every time?Every couple thousand hours it does an "extended" pixel refresher, this is in addition to the "mini" one that happens almost every time it's put into standby. Nothing to worry about![]()
Every time you turn it off at plug it can't do the pixel refresh so it resets , if you leave it at standby when you go sleep it will refresh the tv itself at night automaticThe only time I have seen the message on mine is when I turn the TV off at the plug. Ever since leaving it on standby I have never seen the message again. Every 2000 hrs you'll get the prompt for the big refresh that takes about an hour.
