Mine was running 1080/1440p @ 120 FPS from my 1080 no problem last night, so I'm not sure what your issue may be.
Mind you, that's just what I set the output to be. I didn't enable anything like G Sync as far as I'm aware.
My Vega 64 doesn't seem to be capable of 1440@120Hz (goes to black screen with only sound), is this a limitation with AMD? I'm using a HDMI 2.1 cable and my 1080ti is fine with it.
Also, and apologies if it's been asked previously, is the HDMI 2.1 cable spec going to be fine for 4K@120Hz when new GPUs are released with the capability?
@Woodsta888 this panel is both Gsync and Freesync compatible, however that's not what I was asking about in the post you quoted.
If it works already then fine. But are you trying to run VRR whilst doing 1440p @ 120hz on the AMD card?
Does it work without VRR?
I know that it is in the manufacturers bumf that this is a freesync TV, but from the AVSforum thread by an OLED Guru I read this for the CX models;
new AMD FreeSync compatibility - available via a future firmware upgrade at the end of 2020 (the FreeSync level that is supported: "AMD FreeSync Premium" that provides: tear-free experience, at least 120hz refresh rate at minimum FHD resolution, support for low framerate compensation (LFC), low latency) - also is unknown if FreeSync will be made available to the C9;
Read back a page or two in the thread, LG released the freesync enabled firmware a week or two ago Works perfectly on even older Vega cards!
Seriously considering one of these screens now that the new Samsung G9's have been put back. I have a 1080ti - can i use the freesync aspect of this screen? Ive heard mixed messages about to 1080ti being able to use gsync? Has anyone here used one with a sim racing rig - id be attaching it to the rig. I'd still prob prefer the G9 49 as its curved and lower pixel count... feedback appreciated!
right so i cant use gsync or freesync? Hmmm... not great. I'd be forced to use vsync to reduce tearing?
Also, Nvidia want you to get a new card.aaaah! i see lol. I knew it was too good to be true ;o)
