Nvidia control panel - > change resolution -> bottomWhere are you doing that in settings?
By the way, I do think scaling is better set at 100% as it seems to have compatibility issues.
Leave HDR enabled in windows at all times.Got it.
So, are you leaving HDR enabled constantly even if the game you are playing doesn't support it?
on the desktop it wont but in game it will as HDR on the desktop is a application frame that supports HDR@smogsy when I enable it, then it's on all the time as in it never switches between SDR & HDR.
It's around 13ms, which is excellent. If you need faster then you wouldn't even remotely be in the market for this. You'd be looking at some 240hz 1080p options instead, and likely be some sort of pro gamer playing CS:GO 24:7.
13ms is excellent for a TV. It’s really poor for a monitor, and for gaming, people would balk at that kind of figure on a monitor
When loading a game that doesn't support HDR it is still enabled as HDR Game. Maybe it's my Windows version as I've been stuck with the May update not being ready for my device.
Edit to add:
I just completed the prologue in Death Stranding 4k with HDR enabled. Just wow, those visuals are tremendous. This feels like a genuine technological upgrade that quickly goes from luxury to essential. I can't wait to see this with 4k@120 with Gsync.![]()
overall motion clarity will certainly be impacted by the better response times, as will running it at 120Hz, as will enabling BFI too. lag is still low, I was just making a point really that people saying "13ms is excellent" needs to be taken in context. for a competitive PC gamer it would be way too high for instance.I have mine side by side with a BenQ XL2730Z, a very fast TN monitor. With the CX at 120Hz, the CX still feels faster to me. Others have commented that this is likely due to the instant OLED pixel response, despite the added input lag of the TV?
Nice, good to hear. Thats on my list to play. Does it have any NV exclusive features? If so I may hold off until I get a 3000 series card (or big navi, assuming it offers similar features, speed)
Not got any NV features that I noticed. I only dropped a couple of settings to keep it on or around 60fps.
The only restriction for this device is that your DisplayPort 1.4 hardware supports DSC 1.2. This feature is supported on today's Turing RTX, and RDNA powered graphics cards
This DisplayPort adaptor apparently does 4K@120Hz so you don't have to wait for a HDMI 2.1 graphics card to be released.
https://www.overclock3d.net/news/gp..._4k_120hz_hdmi_2_1_possible_on_today_s_gpus/1
I wonder if gsync will still work with it ?
I have one of these on order and it should arrive we me tomorrow, i will let you know if it's any good and if G-sync actually is supported.
CAC-1085 DisplayPort™1.4 to HDMI™ 4K120HzHDR Active adapter M/F The Club 3D CAC-1085 is the perfect solution to connect to any HDMI™ 4K120Hz ready displays. If you have a DisplayPort™ 1.4 ready PC or any other device that lacks the new HDMI™ 4K120Hz specification, the Club3D CAC-1085 will be the simple way to upgrade your device and connect to your new TV. With its DP1.4 DSC 1.2 video compression technology, this adapter is able to convert DP1.4 video signals to HDMI™2.1, supporting video display resolutions up to 3840x2160 at 120Hz creating life like colors and movements with HDR giving users the ultimate visual experience. Support for G-Sync, FreeSync and VRR bypass. The Adapter is powered thru an USB Type C to USB Type A cable(provided with the product). Features • Compliant with VESA DisplayPort™ v1.4 Specification • Compliant with HDMI™ v2.1 Specification • Support both HDCP 1.4 and HDCP 2.3 • Support DSC v1.2a and backward compatible with the former version • Support Max. resolution/refresh rates up to 8k@60Hz - 4k@120Hz • Support Dynamic HDR • Sound Support 5.1-7.1
