Someone on reddit couldn’t get it to work with Gsync. https://www.reddit.com/r/OLED/comments/ho1aal/how_to_get_4k_120hz_on_an_lg_c9_today/fxetych/
Thats on a c9 screen though, it might work on a cx?
Ah, fair enough. Yeah, can't see those competing for awards, tournaments wanting to move from their 24" 240hz screens to a 48" panel! Heck, I believe there are loads of CS players still on their CRT's!
Question for owners as I've heard reflections are noticeable:
If sat at approx 90cm - 100cm from a wall mounted LG CX 48" with a backlit gaming mechanical keyboard would you see this keyboard reflected in the TV or is the angle such that it won't be seen?
And when the screen goes black are you faced with your own mugshot a lot as well?
Cheers
overall motion clarity will certainly be impacted by the better response times, as will running it at 120Hz, as will enabling BFI too. lag is still low, I was just making a point really that people saying "13ms is excellent" needs to be taken in context. for a competitive PC gamer it would be way too high for instance.
Their catalog claims it does
Which is EXACTLY why I said a pro-gamer would be looking at a different monitor lol!
Agreed. I expect most people who are somewhat serious in to their gaming might still be put off by the lag. Even though the panel no doubt offers great response times, amazing contrast etc. You don’t have to be an eSports or pro gamer to be put off by that kind of lag figureYet another interpretation of 'competitive' means 'pro-gamer. LOL!![]()
I did notice some heat coming from my 48CX the other day, but thought nothing much of it as TVs do produce heat. I'll check how warm the rear section gets now that this has been mentioned.
I would assume this is by design and not causing any actual damage?
Do you REALLY think LG design these OLED's to need an additional external fan cooling them? I mean come on...Aren't the earlier models prone to damage from the electronics, causing a blob on the panel?
OLED degradation is heat related, so may be a good idea to have a fan cooling it.
Do you REALLY think LG design these OLED's to need an additional external fan cooling them? I mean come on...![]()
Those monitors have cooling due to the G-SYNC HDR module requiring it.I dunno but some of the ROG monitors have fans on them by design. Depends also if your TV has a very slim bracket making it very close to the wall and/or if the panel is in a deadspace for air movement in the room with no draft to remove the heat, heat could build, but all TV's get warm. These are designed to be purchased in hot countries too so imagine it's a non issue.
