A lot of things that are mentioned in these cases are usually unnoticeable or only applicable in specific situations, but of course now that nowadays we ask for reviews of TV's in the most exhaustive of engineering-level detail we exaggerate the impact to the levels where all of a sudden such minor niggles are suddenly "unacceptable" to those who consider themselves knowledgeable enthusiasts. The fact is if you never heard about then you would likely never notice.
I am not saying it isn't good to have all the information, I am a man of science and in the end it is our hard-earned money that we want to mae sure we are spendng correctly, but I think that collectively we do develop a level of perfectionism in our expectations that is often unrealistic and in many cases not even necessary. It's easy to get carried away readig all of this stuff and I consider myself among those that sometimes do before I give myself a reality check.![]()
Can you use an oled for any productivity at all?
Ie, static images for hours a day
Yes you can, but you're taking a risk long term with £1500 that the screen may develop permanent visual artifacts most likely where the toolbars are. Use a dark theme at least. ;PCan you use an oled for any productivity at all?
Yes you can, but you're taking a risk long term with £1500 that the screen may develop permanent visual artifacts.
I can confirm that VRR on XBOX One X is also affected. This looks just horrible!!! Both pictures are made with the same exposure time. VRR causes raised blacks and wrong gamma.
https://twitter.com/EvilBoris/status/1260336886138142723The theory is that VRR disables the black crush that LG applied to hide the chrominance overshoot and that is closer to how it Should be. I’ve got the crush calibrated out and here are 2 shots. VRR on and Off. Tonemapping disabled on the phone and same exposure .
care to share where from ?
Static images for hours a day? You dont take any breaks and just sit there for 12 hours with the same image on screen?Can you use an oled for any productivity at all?
No but the task bar, and other such menus could be there for a lot of the time.Static images for hours a day? You dont take any breaks and just sit there for 12 hours with the same image on screen?![]()
If you use moving screensavers that kick in after a short time of inactivity then you are very likely not going to get burn in. Tests on modern OLED's show that it takes many hours of static images to get burn in, more than people realistically display at any given time.
And I repeat the question... how often are you doing this for 10+ hours without any break? You don't get burn-in from just a few hours.I'm talking more of photoshop where half the screen is menus. Or coding software where the same applies
Whaaat? I do productivity stuff without "doing it for a living". I photo edit, I use office, etc etc.Uhm... if it's being used for productivity, I'd expect it's probably done for a living - so you're definitely looking more than a few hours a day. 8 hours a day, even with breaks and other use in between, is going to add up. Burn in is cumulative.
