@Nexus18 game mode is essential for Freesync/Gsync.
Your post has pretty much confirmed that my "guide" will be restricted to the CX models as e.g. preset Technicolour isn't an option with the CX models.
I'll have a look at the sharpness settings.![]()
I used auto also but like vincent T posted in his video above, he says the black setting should not be on auto or high it should be set on low for xbox at least, but I tested it on some videos and he was right now my blacks are more black while on auto it was more white and washed out.
Crazy that one setting can change the picture quality so much, really it's almost impossible to get settings right it seems even for us geeks haha
One would have thought auto would be able to figure out how to auto black correctly
Vincent set it to low for hdr and sdr I believe, just going to leave it on low.
Just make sure you aren't crushing blacks as when using RGB full/signal, black setting should be on "high", if you're sending a "limited" signal, then it should be on "low".
I have to admit I'm also very afraid of burn in, even though I purchased the warranty from JL. Even typing this, I'm conscious of how long my chrome window has been static on screen, and I just minimised my Outlook because it had been sitting static for a little while. I had a folder of lovely 4K wallpapers ready for this upgrade which were cycling every 1 minute, but the static colourful elements of them mean I just set a plain black background and this chrome window is currently floating in a sea of inky black. I'm sure with time I'll get lazy and stop caring so much, but it's absolutely something potential buyers should be aware of. It's in the back of your mind, whereas it never ever was on my ultrawide.
Thats why i dont think i could go OLED for a computer screen, i wouldnt be able to enjoy it with always worrying.
Consoles don't utilise RGB full like PCs do. Although again, perhaps, it is another weird setting that only applies to this particular model.
If you're are using RGB full and have the TV set to "low", initially it does look better as in blacks are definitely blacker and the image on the whole is more punchy but you are losing incredible amount of detail since the black level isn't correctly set, good example for this I find is batman arkham knight, you just lose all detail in the cape/suit
I've been doing some testing this morning while gaming, and I think you're right. Best settings are RGB full with blacks set to auto which seems to default it to high.
Lg has included so many software features to prevent burn in, I have the JL insurance just in case the world or LG is wrong so sleep comfortably but I ain't worried in the slightest we have screen shift, logo luminance, screen saver, ABL, ASBL features designed to prevent burn in.
I have not adjusted anything in the slightest but if you do feel you need to then you can adjust to prevent it.
Yeah I think it was just because it was new out of the box, I'm sure within a little while I'll be using as a normal monitor. I got wallpaper engine off steam and have a lovely dark galaxy moving wallpaper now, so that's a happy compromise - because there's so much screen real estate I always have some elements of the desktop wallpaper showing!
The big thing which I miss though is my desktop icons. I wish there was a way to hide them without having to remove them from the desktop altogether, because I found that very useful having a few regularly accessed documents etc sitting there.
Hmm so Vincent T one of the most popular Youtube TV calibrators well ex, saying you should put it in Pc mode for RGB for better improvement and set to black to low since auto/high gets it wrong and can introduce banding..... could be wrong ?
I guess the best way to test it is test it out myself and compare auto/low/high, will try and dig up some dark videos and see if the detail is lost.
Interesting to see how popular a higher-priced smaller OLED is:
Didn't watch the video but was that video of his not for the new xbox? If so, like I said, wouldn't go by that since consoles are very different with their signal processing compared to PC, I think consoles use/prefer a "limited" signal.
For PC GPUs and any type of display, it has always been RGB full setting wherever possible and then high black level on the display.
If in SDR mode, you can probably use this site to test if black levels are being crushed:
http://www.lagom.nl/lcd-test/black.php
Here's a starter for 10 regarding best settings. Please feel free to correct any errors or add any additional info you feel is relevant.
- These settings are based on a 48CX panel with Nvidia 3000 series GPU. Please feel free to suggest info for earlier Nvidia cards or AMD cards.
- The settings are for Gaming only.
- The text in yellow is open to discussion as these are specific to LG48CX and at time of writing I'm not 100% sure these are best settings.
- I've assumed Windows colour profile is to be default, however if anyone has a .icm file they want to share for their panel then let me know.
- I might transfer this to it's own thread if/when we agree it's a solid guide.
TV Settings
HDMI Input mode: PC
Picture Mode Settings:
- Preset: Game Note: This is essential for VRR to work properly, low latency etc.
- OLED Light: 100
- Contrast: 100
- Brightness: 50
- Sharpness: 10
- Colour: 55
- Tint: 0
- Advanced Controls
- - Dynamic Tone Mapping: On
- - White Balance:
- - - Colour Temp: Medium
- - - Method: 2 Points
- - - Point: High
- - - Red: 0
- - - Green: 0
- - - Blue: 0
- Picture Options:
- - Black Level: Auto
- - Motion Eye Care: Off
Energy Saving: Off
Aspect Ratio: 16:9
Additional settings:
- Eye Comfort Mode: Off
- HDMI Ultra HD Deep Colour: Enabled
- Instant Game Response: Enabled
- Filmmaker Mode Auto Change: Off
OLED Screen Saver:
- Pixel Refresher: Operate once when TV is off
- Screen Shift: On
- Logo Luminance Adjustment: High
NV Control Panel Settings
Manage 3D Settings:
- Vertical sync: On Note: Set Vsync to "Off" in game and consider limiting max frame rate to 118 (or 2 fps below chosen resolution)
Change Resolution:
- Resolution > PC > 3840 x 2160
- Refresh rate: 120Hz
- Use Nvidia Colour Settings:
- - Desktop colour depth: Highest (32 bit)
- - Output colour depth: 10 bpc
- - Output colour format: RGB
- - Output dynamic range: Full
Setup G-Sync:
- Enable for full screen mode
Windows Settings
Colour profile: Windows Default
Display settings:
- Use HDR: On Note: This should in theory mean that HDR is disabled for SD content, but you may have to manually disable it in certain circumstances.
These settings is too high for a desktop OLED TV at 80cm gaming
- OLED Light: 100, I set to 80
- Contrast: 100 I set to 75
