just waiting on sorting a vesa mount and a 8k hdmi cable and will have a play about, problem is im stuck on a vega 56 and no sign of being able to upgrade the gpu any time soonThe 1400p is blocky compare to 2160
What dose the new update 03.11.30 fix?
Yep I have the 48 and 55 and the 55 was cheaper.The 55CX is actually cheaper than the 48CX in some places, are there any downsides to the bigger panel?
In my limited experience, modern TVs are brilliant at upscaling - I'd guess it's as they're designed to deal with low res tv signals day to day. I've been using an LG 55" C9 at 1440p and I can barely notice the lower resolution at a comfortable viewing distance.I've seen a few videos of people raving about this oled screen, and the fact that it can sync to gpu is making this attractive to me. Its been so long since I used (crt like) screen is it different to lcd so you can have any resolution and it wont look terrible because its not the specific res of the monitor? And the reviewer I saw mention you cant use it as a main screen because of burn in?
I don't play any racing games, I play Anno 1800 and Valhalla, Odyssey, Origins, Watch dogs legion, and I watch Netflix & Amazon I always mix my content for 12 hours a day
1) Update to allow PC and Console gamers smooth VRR playback
You just reminded me of one of those Amazon Q&As...
Does this washing machine do 1400rpm spin
"I don't know, we decided to buy a kettle with our voucher instead"
OLED burn is mostly cumulative, not per session.
1 hour per day for a year should have the same impact as 365 hours straight (although heat is a factor).
Looking at the burn-in tests if you stay at a sensible OLED light level there should be no issues for the first 2-3000 hours.
A dark windows theme is possibly the wrong way to go. You now have bright white text burning into the set instead of a large area of more evenly lit pixels.
If it's cumulative, what's the point of the pixel refresher routine my LG runs every now and then?
Fair enough, makes sense I suppose! We only notice the anomalies, not a gradual dimming... like a frog in a slowly boiling potThe pixel refresher attempts to wear out all pixels evenly.
Its sole purpose is to make each pixel equally dim.
