Hooked this up to my 3090 with hdmi 2.1. The LG half of the time stops recognising the PC and shows nothing connected. Any ideas?
The manufacturer becomes the first to confirm that such NVIDIA SKU even exists. The listing reveals that two ROG STRIX graphics cards are in development: ROG-STRIX-RTX3080TI-O20G-GAMING (with factory-overclocking) and ROG-STRIX-RTX3080TI-20G-GAMING (likely to feature reference clock speeds).
According to ASUS, the RTX 3080 Ti SKU would feature 20GB of memory, which would confirm the previous rumours about the graphics card’s specifications:
The graphics card is expected to feature GA102 GPU with 10496 CUDA cores, the same number as the flagship RTX 3090. It would appear that RTX 3080 Ti will simply offer less memory (20GB vs 24GB) and carry a lower TDP, to better combat Radeon RX 6900 XT series.
NVIDIA was initially planning to launch the RTX 3080 Ti in January, although new information seems to confirm that the SKU has been pushed back till after the Chinese New Year in February. It is unclear why the 3080 Ti listing appears on the ASUS website right now.
Some early reports of the new CX firmware 03.21.09 suggesting it offers better compatibility with the 30xx Nvidia cards and hdmi 2.1 cables in general according to guys over on Avforum's at least.
One said it fixed his display vanishing @ 120hertz.
Looks like its a slow roll out though should be more rolled out over the next week or two.
Just use certified cables
It's costs a bit, but I got a cable that is ultra high speed Hdmi 2.1 certified and it's worked without issue at 4k 120hz HDR 10 bit
I bought one from b&m because I needed to get the TV back closer to the wall can also lower down to the thickness of the stand plateGuys can someone recommend a table stand for the 48" version of this tv?
I've done some measurements and the tv wont fit where I want it due to the tvs stand, so I need another stand that will drastically lower the monitor height
IMO this will be 'the' card to get, the card that will cope with newer games at 4K without being constrained by VRAM concerns. I think it will also be faster than the 3090, though time will tell.
I got my sons setup all built up and installed. I needn't have worried about the larger 49" screen size - it fits in perfect![]()
It's probably for him really![]()
So on my 55" CX I take it that some pc games will not enable HDR Forza 4 for one. Problem is the panel auto kicks it in when it detects a game launch. However the tv will not let you switch on the toggle switch in Windows settings before launching a game. Doom eternal works perfect however. It's annoying so if anyone has a solution other than don't use in Windows then please let me know.
