- 1 May 2013
- M28
MLB is the Currys exclusive one.Stand on the PLA is slightly darker I believe, it's exclusive to Curry's that one.
Just the stand front is silver on MLB other than that they are identical.
I’m not replacing mine just to get Hd via eArc audio. I tried that with the Samsung 90r it was crap compared to the 2700 even with rear speakers. I will upgrade if Yamaha release a 2.1 2700 or if I send them enough email requests add eArc to the 2700..... lol
How do you display the picture without the no input label there all the time ?
Them gallery pictures look cool, I take it they change every minute or so to a different image?
Hope they have these on the CX.
Yeah every 30 seconds or so. Some calm music plays with it too.
Just picked up a 65C9, upgrade from 55eg920.
Great screen. As well as screen uniformity etc being far better (although this is more panel lottery territory), the main thing that stands out to me is the 120hz in gaming. This is a lot better than lcd. Nearer crt sharpness. Much better at 120 than my monitor at 165. Now I'm torn between 1440p 120 and 4k60. Will be great when 4k120 is available from a 2.1 gpu.
Is it 2.1 that makes this work? My CX can do 4k120 from a GTX 1070 (so HDMI 2.0b), it just can't do 10-bit colour simultaneously.Just picked up a 65C9, upgrade from 55eg920.
Are you sure? Could you post a vid of this as AFAIK even @8bit 4K would need about 30Gbps of bandwidth for 120Hz and HDMI 2.0 only goes up to 18.Is it 2.1 that makes this work? My CX can do 4k120 from a GTX 1070 (so HDMI 2.0b), it just can't do 10-bit colour simultaneously.
Sadly they've only enabled VRR/G-sync Compatible for 20 series and above so I might have to upgrade![]()
You're right, just checked - it's not full range. It's driving 4k120 but only at YCbCr420, and limited dynamic range. All the options shown are fixed i.e. nothing else on the dropdown. Same for 100Hz.Are you sure? Could you post a vid of this as AFAIK even @8bit 4K would need about 30Gbps of bandwidth for 120Hz and HDMI 2.0 only goes up to 18.
And see the TV to low, I tried leaving mine on auto for my Xbox (which was set for limited), but when I flicked from auto to normal there was no change but the was when I went from auto to low.Make sure you are using 'Limited' range RGB under the Nvidia control panel if you have an an Nvidia GPU.
