Yup, although mine lost most of its stickiness since I kept attaching and reattaching after cutting a bit away each time so have had to use some sellotape.
ThanksI definitely recommend it for any monitor.
Have you tried adjusting cleartype settings?
Tried different cables?
Checked your nvidia/AMD control panel sharpness/display settings?
New owner reporting in!
Whilst calibrating the screen with colourmunki photo, I found that the 'super energy saving' mode caps your minimum brightness at 149cd/m2. The recommended brightness is 120cd/m2, which is brightness 16 with energy saving off.
My panel has faint bleed in the bottom corners (on black screen) and none of the dreaded glow.
21:9 gaming videos coming soon!
If your planning to buy a displayport cable then read this:
http://www.displayport.org/cables/how-to-choose-a-displayport-cable-and-not-get-a-bad-one/
Yes you can add me - Killabyte28 (EDIT: or my real name is M.Long)If your name is not listed in the OP and you own once, can you respond so I can update please?
Thanks![]()
these monitors any good for fps gaming?
