So for example, crysis 3, 3440x1440, high to medium settings. 45 to 60fps
I can put it on 2560x1080 and max it out. This is the new mac pro under windows.
Crossfire works. It detects the cards as two 78XX. 14.4 drivers.
The 34um95 should arrive with displayport cable, hdmi cable and dual link dvi cable according to the Linustechtips video ive seen. The little brother the 34um65 should only come with hdmi from what i know.
no dvi cable (as no dvi ports) but the other two are in there
So mine came today who's smart idea was it to include a two pronged plug which doesn't work in UK?
Where did you get that from??
Is that the 34UM95? Gibbo said German stock was used in the first batch (approx 10 or so units), should have been UK stock after that unless something changed. Mine from the second batch of stock came with a 3 pin UK plug.
Mrk, contact the ECC asap! They can take over a week to get back to you, so the quicker to contact them the better. They can really help if they're needed.
It's damn shame you're still dealing with this, especially since the monitor be becoming very prominent in online retailers. They should have just given you a refund or new monitor within the first week.
Wow. Has that still not been sorted for you? I saw the thread when you were first having problems which seems like years ago now. Sorry matey. Are there any alternatives available that you could get if you spoke to your card issuer?
