Just tighten the tensioner bolts with the supplied hex key thing supplied with the MX. I have had no problem with the 34UM95 on the Ergotron MX. You can get the bottom several inches off the desk surface at max height as well.
I don't see any reason wy you could not position the monitor left, middle or right on your desk providing you clamp the MX base in the right place initially.
This is how high I have it set, it will go a couple more inches higher for the record:
