Mine also. Only really visible in very dark conditions on dark screens. And even then, only when I looking at it from certain angles.mine has a bit of a glow but no real bleed issues. Or maybe im just really tolerant!
I'm connecting to the 34UM95 using a DisplayPort cable with the 1.2 setting turned on. I'll try to lower the built-in speak volume to zero as I use an external pair and see if that stops the popping.
I don't notice any flickering with DP 1.2 enabled.
actually mrk which LG contact did you use, just incase my decides to mess up.
Yeah the 29UM65
I am going to watch a few clips later and play a few games to see if the dead pixel is noticeable, if it isn't and there is very little back light bleed, I might just keep it as chances are the next one will have terrible back light bleed again
How come you didn't go for the 29EB53, it seems more featurerich than the one you have selected, and the adjustable stand is really good..?
When one of my monitors had a pixel issue (almost central) it bugged the hell out of me until it finally died (it was flashing constantly) but I was still aware of it when it was just stuck. I'm bad enough if the stuck pixel is to the side but not near the middle.!
Bad luck there.
Mainly because it was the newer version and this one was in stock where as that one wasn't at the time of my order and iirc this one was £30 cheaper too.
Adjustable stand is nice to have, however, this one seems good enough for the height etc. and the depth with this stand is very small (my desk depth wise is very small so the further back the monitor can go, the better), I do plan on wall mounting my monitor at some point in the future too.
I think I am going to seek another RMA tbh as considering the price of the monitor, I expect to get a product that hasn't got any defects and now that it is a bit darker, I am noticing back light bleed too (mainly the bottom left corner), certainly not as bad as my last one but still not good enough imo.
Yeah the 29UM65
The panels of the 29EB53 and 29UM65 are the exact same so should the contrast ratio not be the same?
Yup know what you mean! Kind of why I am hesitant about returning this one as I just know with my luck, I will get one which was as bad as my first one for back light bleed
I posted my pics to the LG tech bod via web chat. He immediately agreed it was unacceptable and has arranged for it to be collected on Monday. It will then take 5 - 7 days to be repaired and returned to me with a brand new panel, properly fitted and checked before being shipped at their expense.
I've decided this is a better approach than rolling the dice on another one via OCUK or elsewhere.
In the mean time I've had time to play around with it some more, and at this price, it's a great piece of kit. Gaming and movies are awesome!
I'll let you know how it turns out
I don't know if the panels, or what is driving them, are the same but I'm only noting the spec on OC's advert which shows that difference in contrast ratio.
You might want to give consideration to what Figuz did with his monitor, I would tend to think that it would be too risky hoping for anything much different from the rest of the stock that OC supply to think that it could be any better, or worse, for light bleed.
It would be interesting to note what the bleed will be like for those who have returned them for a fix to LG when they return.
That does sound good!
Will see how my panel looks tonight and if I am not happy, reckon I will do the same as you.
Thanks.
Just had a look at the contrast ratio specs are both the same
I just hope they completely remove the back light bleed and don't just reduce it to "acceptable standards"
