Lads someone answer me this ive been looking at these 29 inch screens now all day and ive pretty much digested every bit of information out there on them. And i think i came upon something. But i think i need someone to explain if i am possible correct and another kind soul with a DELL u2913 to tell me if he can adjust both brightness and contrast in his preset calibrated SRGB mode.
Dell use contrast of 75 on thier monitor where as everyone else is set to 50 and Dell top out in max and min brightness and luminence on thier panel. One review said it had the best blacks out of all the panels available and then i noticed warnings about white crush above 50 contrast on the AOC. I thought this strange.... And then noticed that someone mentioned white point correction with RGB sliders and the people using contrasts of 50 like AOC used lower RGB too like 49,50,49. Dell on the other hand used a full 75 contrast and thier RGB are 100,99,100 etc.
Is that possible? Did Dell just use a trick here i could potentially do on the AOC and save some bucks? Because AOC has less input lag, Control over overdrive of which Dell has none and it is cheaper too. But it also has the lowest luminance of the panels. BUT all the reviews state calibrated contrast ratios from 1100:1 roughly and Dell do not really have a lead over AOC here so why the hell are contrast and RGB different and can it make it look better if done right?
Expert in calibration is needed where is PCM2?
