Yeah I saw the same video, unfortunately all the z690 DDR4 mobo have like a PCIe Gen 3 down there - mine has a 16x slot at 4x speed. Also supposedly those extra long extensions are of iffy quality which might not matter now but will do once we have GPUs that require PCIe 4 bandwidth...
I'm pretty annoyed by the whole thing (to the point I feel duped by Lian Li) and now agree that the upright metal piece should have been thrown in with the Evo and at some point you could select the PCIe extension you wanted. I am considering daisy chaining two so the first goes behind the mobo entirely and then the second connects to it on the mobos left side and into the top PCIe slot - no idea the lengths needed and if that maintains PCIe 4 compliance.
I do find it surprising that some youtubers think you have to have the mesh front with the upright GPU - the less said about Bitwit's review the better...
ps3ud0![]()
Check out the following video he did use strix 3080 and with it upright temps were worse what surprised me is that with gpu vertically mounted he got the best temps , might be different with the FE cooler design ?;
And front mesh with fans hardly makes much difference
https://youtu.be/tAeoVEY5JRk
