Don’t know where mines got to then. Ordered white on Nov 21st, still nothing.likewise. Mine has shipped today. Ordered 14th December and i went for the white variant
Thanks for confirming. I just can't seem to find one anywhere
Contact CS?
Order 20th November and came on Monday (11th Jan). I'm building it up slowly and will post photos when done.
Had to modify pump brackets for my D5 too. SF PCI-E power cables will reach above and below to my 3080, but there's not much room to spare. I've ordered some extensions so I can route it more neatly.
Thanks!
Yeah I think I'll likely get custom cables anyway eventually, would be nice to know if we could actually build without them though.
It looks like it’s too tall to fit underneath the vertical gpu mount as it comes up to the third slot, so I’m thinking of cutting out where the side intake is and doing something there. The holes in the side panel look too small to let any decent airflow through, so even if I did put a radiator or fan there I don’t think it would get great cooling.
Corsair 750w psu cabkes are plenty long enough.
I could loose 2cm off Atx cable
And maybe 5cm off cpu cable.
I was surprised how tight it becomes lol
With my Dark hero ATX build it was tight getting the 3 unifans at the top, CPU cabling took a bit of bending to fit under fans.
360mm HW Labs rad at the bottom doesnt give much room for pipework at the front either.
Waiting for 280 side rad and 140mm fans before the majority is in so it all running air at mo.
I took the plunge and painted the inside of my white case 'Black'
Came out alright, and the contrast is better with all black components and RGB
Yep. Will need to go down bottom. So pump will be above rad and could shorten life of it if there is any air in system.I've seen a video on youtube where a builder stated that you could maybe fit an ATX motherboard and still have room for a thin 360 AIO. Can anyone confirm this?
