Looks great, I've been waiting for someone to put a V354 build up before I bite the bullet and buy one.
Think I'll be buying a V354 and 6850/70 in the next 2 weeks.
Is the CPU placement on that board lower than it normally would be on a 775? I'm planning to get a TRUE120 in there facing upwards, but it looks like your PSU is overlapping your H50?
*Edit*Just got some pics out, and it looks like it is, can you foresee any problems with a TRUE120 in there?
Cant really comment on the true as ive not tried to fit such a cooler it was my idea to go with the h50 all along, id thought of the h70 but wasnt sure the tubes would be long enough.
theres a thread over at Hardforums about these and various coolers people have fitted etc
Very nice build.
Very nice case, how much did it cost, if i may ask?
Very nice overclock and temps
Do you mean in total? I already had the parts with the exception of the case
Nice powerful little build mate.
Cheers
nice one - looks good.
How loud is it with all the fans running?
Its not bad at all, when the gpu's are under load they do spin up a bit, but ive got the fans on the built in fan controller and its pretty quiet, theres a hum from my two hdd's, roll on the days of cheap 1tb ssd's
