I need some advice on what CPU cooler to get.... any ideas?
How high is the case with the feet removed?
I kinda need an exact measurement
240 Rad on the front would be no problem, the position of the 140 fan might might make it a tight fit with the motherboard and any large caps, would need a slim fan for sure.
I'm away from home at the moment but will give a measurement soon as Im home Wednesday.
306mm with feet removed.
thank you bradmax57 definately given me a lot to think about my next build,
how much did this build cost altogether roughly?
Anyone know if an H50/H60 can be fitted WITH the drive bays ALL in place? I assume it might need a slim fan fitting to happen but can anyone confirm or measure the space from case front to HDD cage?
Thanks
have you actually seen any pictures on this i was going to do it when i get my case but didnt know if it would fit2 x 120mm rads sideways mounted would fit from what i remember
