Ah just what I was looking for... a V354 owner and lots of pics.
Can I ask if the space under the optical drive is designed for fitting (or possible to fit) a 2.5" drive? I can see my server migrating to this box and I'd probably use all 7x3.5 bays as well as optical.
Is it possible to disable the LEDs on the supplied fans or must I install new fans? My server is in my office where my cats sleep and I'd rather my babies were not bathed in an eerie blue glow!
There are 2, 2.5" pre-drilled mounts on the floor of the case,there is also as you mention a space under where you'd put the optical drive which while has enough room physically (just) it has no mountings for a 2.5" drive.
I bought a Lian-li EX-533b slimline adapter to enable the use of a slimline optical drive and a 3.5" drive both in the optical bay,it has a mount which sits just under the optical drive for either a fullsize 3.5" drive or a 2.5" drive.
I wanted this so I could do away with the drive bays for the rads I put in,although it will serve the same purpose for your needs!
As for the fans,aye they can't have the led turned off.
They were the first thing to go for my build,I replaced them with 1150 rpm gentle typhoon's hooked up to the cases fan controller and they are near silent.
I wanted a small gaming monster,it's not perfect but with SB running so cool it's damn close for quiet gaming.
My original intention was for m-itx but after a couple of setups I just couldnt live without case contained silent custom water cooling which I'm used to.
