I'm really curious about in wall speakers. My plan is when we either buy or build a place is to completely upgrade my home cinema setup and in wall speakers will be ideal given 2 cats and wife wanting a sprog or two running around.
Also you're using the same speaker as a centre that you are using for fronts. Unless I missed something? Will this cause balance issues do you think? Or can it be corrected/balanced out by the amp?
Not trying to nitpick. Genuinely curious!
Another note. When it comes to the electrics, decorating, basically all the prep/setup work. Are you doing this yourself or do you have a firm in to do it?
I can only imagine the looks if I asked a Portuguese decorator to paint my ceiling the same colour as the walls
I also really like the blue. Very neutral and understated.
