Luxury car for £6000...
22 Apr 2008
Bryn Celyn Wales
Well, if you're determined for the RR, for me, this would be one I'd be looking at and 100% not the diesel... 82k miles, only 2 owners which is good... it's nice and fast... being a proper engine and all... luxury inside like you wanted, looks expensive... surely this is what you would want judging by your original post? Ok, MOT says a few problems, but you can check it out, haggle and ensure that's it's not a dud... but it's ticking boxes you wanted surely?
https://www.autotrader.co.uk/car-details/202101278422245?advertising-location=at_cars&radius=1500&make=LAND ROVER&sort=mileage&postcode=ch87qg&include-delivery-option=on&fuel-type=Petrol&maximum-mileage=90000&model=RANGE ROVER&onesearchad=New&onesearchad=Nearly New&onesearchad=Used&price-to=6500&page=1
Check mileage recorded at test, MOT expiry date, defects and advisories, and view test certificate
Date tested 3 March 2020
Pass
View test certificate
Mileage 81,744 miles
MOT test number 4843 6319 2325
Test location
View test location
Expiry date 23 March 2021
Date tested 27 February 2019
Pass
Mileage 72,675 miles
MOT test number 4406 8632 1499
Test location
View test location
Expiry date 23 March 2020
The MOT test changed on 20 May 2018
Defects are now categorised according to their severity – dangerous, major, and minor. Find out more
Date tested 24 March 2018
Pass
Mileage 67,549 miles
MOT test number 7800 7548 4229
Test location
View test location
Expiry date 23 March 2019
Date tested 6 March 2017
Pass
Mileage 63,955 miles
MOT test number 1538 4084 0500
Test location
View test location
Expiry date 5 March 2018
Advisory notice item(s)
  • Windscreen has damage to an area less than a 10mm circle within zone 'A' (8.3.1a)
  • both front caster arm inner bushes have slight play
  • fuel cap seal cracked but still sealing
  • near side front tyre is damaged on both sidewalls
  • engine covers and under drays fitted obscuring some components
  • near side body paintwork contaminated with foreign paint
  • coolant low
  • offside and near side step has slight damage
What are advisories?
Date tested 24 February 2016
Pass
Mileage 63,309 miles
MOT test number 4660 2837 5777
Test location
View test location
Expiry date 23 February 2017
  • Intermittent suspension warning message on dash
  • Both front caster arm inner bushes have slight play
  • Fuel cap seal cracked but still sealing
  • Nearside reverse light cover missing
  • Nearside front tyre is damaged on both sidewalls
  • Nearsie rear, offside rear and offside front all have sidewall damage
  • Engine covers and under trays fitted obscuring some components
  • Oil leak
Date tested 14 October 2014
Pass
Mileage 61,959 miles
MOT test number 5564 7738 4205
Test location
View test location
Expiry date 13 October 2015
  • Nearside rear tyre cut in outer sidewall
Date tested 13 October 2014
Fail
Mileage 69,958 miles
MOT test number 4666 2698 4272
Test location
View test location
Reason(s) for failure
  • Offside Front Tyre not fitted in accordance with side wall instructions (4.1.D.1f)
  • Nearside Rear Tyre not fitted in accordance with side wall instructions (4.1.D.1f)
  • Parking brake: efficiency below requirements (3.7.B.7)
What are failures and advisories?
Date tested 3 July 2012
Pass
Mileage 54,973 miles
MOT test number 3794 1578 2154
Test location
View test location
Expiry date 28 July 2013
Date tested 2 July 2012
Fail
MOT test number 5474 9458 2185
Test location
View test location
  • Nearside Headlamp aim too low (1.8)
What are failures?
Date tested 6 July 2011
Pass
Mileage 50,778 miles
MOT test number 8488 2798 1197
Test location
View test location
Expiry date 28 July 2012
  • Nearside Front Tyre worn close to the legal limit (4.1.E.1)
  • offside front tyre worn on inner edge
Date tested 29 July 2010
Pass
Mileage 45,390 miles
MOT test number 3445 5081 0242
Test location
View test location
Expiry date 28 July 2011
  • Front Brake pad(s) wearing thin (3.5.1g)
  • Rear Brake pad(s) wearing thin (3.5.1g)
Date tested 21 July 2009
Pass
Mileage 40,256 miles
MOT test number 6147 8210 9259
Test location
View test location
Expiry date 22 July 2010
Date tested 3 July 2008
Pass
Mileage 33,423 miles
MOT test number 7612 6578 8103
Test location
View test location
Expiry date 22 July 2009
  • Rear Tyre worn close to the legal limit (4.1.E.1)
19 Dec 2002
Pass
Test location
View test location
Pass
Test location
View test location
Pass
Test location
View test location
Pass
Test location
View test location
  • coolant low
Pass
Test location
View test location
  • Oil leak
Test location
View test location
Fail
Test location
View test location
Pass
Test location
View test location
Fail
Test location
View test location
What are failures?
Pass
Test location
View test location
Pass
Test location
View test location
Pass
Test location
View test location
Pass
Test location
View test location
did i read that wrong it had
Fail
and a day later it passed with
Pass
hmm maybe inputted wrong?
OP
18 Oct 2012
It’s your money, but personally I’d wait and see if a cheaper SC one comes up, or pay the extra. As you can see from the comments on this thread, I’m more open to running cars like this than most people, but even I would think twice about buying a diesel model.
Just out of curiosity, what are we saying is the issue with the TDV8? I appreciate your feedback and comments. But, it appears other people just say, it's a money pit or the TDV8 isnt a choice they'd make... With no facts backing up said statement. My uncles, boss', plumber had one and it was really unreliable.
OP
18 Oct 2012
Pass
Test location
View test location
Pass
Test location
View test location
Pass
Test location
View test location
Pass
Test location
View test location
  • coolant low
Pass
Test location
View test location
  • Oil leak
Pass
Test location
View test location
Fail
Test location
View test location
Pass
Test location
View test location
Fail
Test location
View test location
What are failures?
Pass
Test location
View test location
Pass
Test location
View test location
Pass
Test location
View test location
Pass
Test location
View test location
To me this looks tatty and like it hasn't been cared for. But I could be wrong, I often am.
28 Sep 2012
Monterrey, Mexico
Turbo failure, injector issues, EGR issues. Turbos alone are a 20hr job IIRC and seem to be a pretty common failure. I’ve heard of head gasket issues as well but I’m not sure how common those actually are.
Compare that to the 4.2 SC engine which I’ve put easily 100k on over 3 different cars with no issues whatsoever. My dad also has a Jag with that engine, no issues there either. It’s simply not as complex an engine as the TDV8.
OP
18 Oct 2012
Consider me told.
12 Jul 2007
South East
9 Dec 2009
Bristol
@Transform_IT I appreciate your post wasn't asking whether your car choice was a good idea, but when the overwhelming majority of responses from car enthusiasts (presumably) say don't get this car, it would be foolish not to take heed of the advice given.
22 Apr 2008
Bryn Celyn Wales
Look at the state of that.
Is it too much to ask for someone to just own a "nice older car" these days without thinking they know better than the original designers? That one looks like it has been randomly attacked by the owner and his can of gloss black Halfords paint.
And that's what we're trying to show, you can't really get a luxuary car that will be low mileage, mint condition, looks ace and will look great on thwe drive for £6k (especially a Range Rover which is what this is all about really)... what you're seeing there is the lowest level of luxury unfortunatly, hence the overwhelming response of, probably not a good idea. But if the OP is deffo going that way this is the kind of 4x4 he'll be looking at imho. A saloon will be a better choice really, Jags, Mercs and BMW's and Lexus seems to be where the money should go...
For me, it's why I didn't try and buy a 6k luxury car, because it's borderline impossible, it may look like you can but nahhhh for me, you up your budget OR you downgrade your expection. My main things when I buy a car are:
1). Do I really want that car and I'm not buying it purely to show off i.e. it's what I WANT.
2). Mint body work is essential and invariably that comes with low mileage so these two are usually linked unless it's been someones pride and joy, but I've learnt lessons of higher mileage cars now.
3). Don't go to the bottom of the price bracket for that particular car i.e. I was looking at Bentely Continentals... and that would mean sacrifices... on a Bentley... I mean... I had to slap myself in the face
4). Know exactly what the reliability of that particular car is like, what are it's pitfalls and how much as those pitfalls. Think of Tax, Insurance and running costs and ensure you're fine with that.
5). Engine bay and tyres. Sound stupid, but does it look clean and maintained or a dust fest in the engine? Has someone bothered to keep it clean or if it's dusty as hell means it's never opened? Are the tyres cheap? If so I walk away, simple as that, as it's been maintained by A). Someone who is retarded or B). Someone who can't afford decent tyres. Same outcome, early death.
They're my kinda of questions, hence, I'd be lowering expectations for a £6k Luxury car. Luxuary cars are generally around the £60k mark, dependant on your meaning on luxuary and that invariably brings Luxury maintenance costs :(
I still think personally the Jag XF would be as good as I'd be expecting in this price bracket... I mean it's a Jag, all the bits... for less than the price of a Ford KA!
30 Sep 2003
Norwich
Fail
Pass
Probably. My MX5 went back in mileage one year on the MOT certificates but I didn't notice until over a year later :o
I think they must type with their knuckles to stop getting oil and muck all over the keyboard :rolleyes:
12 Jul 2007
South East
Actually, an amusing anecdote in relation to my spray paint comment above - maybe it's not just old cars.
I was out walking my dog last summer, when I passed a house with a white 20-plate Range Rover Evoque on the drive. The owner of said car was in the middle of spray-painting some of the fake wing grilles black, from silver.
I laughed to myself, and then wondered what their leasing/PCP provider will think when they inevitably hand it back. :D
Caporegime
11 Mar 2005
Leafy Cheshire
Even a blind man with a walking stick would think twice about buying that, what a total and utter pile.
