Permabanned
- 23 Apr 2014
- Hertfordshire
Hi - thanks. These are pre-builds - there were no antenna in the boxes. I could try that. Would you recommend any particular brand? The motherboard is a MSI B450 Tomahawk Max (socket AM4) DDR4 ATX.
That board doesnt have wifi so I assume there is a usb wifi adapter or a pci wifi adapter? If its PCI then it should have small antennas.
Can you link to the build at all?
